CDR Subscriber
Hi.
I have a cluster CCM 5.x (1 publisher and 1 subscriber)
CDR is run in both servers.
I think that just the publisher write the bills. But if the publisher's down. The subscriber have a capability of write de bills?
Jaime Valencia
CAR DB is only on the PUB as in all versions
so if you want to use CAR you need connectivity to the PUB
javalenc
if this helps, please rate
java
So, If PUB down. I don't have bills. Correct?
Yes,
Beacuse when your publsiher is down, you cannot read into the data ase to pull out the CDR
Please rate all useful posts
