02-10-2015 12:48 AM - edited 03-17-2019 01:54 AM
Hi everyone,
I have a problem with one of Translation Pattern rule. So,i have 2 Translation Pattern :
1. 9002 translate called to 9003
2. 9003 translate called to an external number : 70895489292 (don't manage by the CUCM).
It's work, but when I called the 9002, on the phone screen, I see the external number (70895489292).
I would change this parameter, but I have not found how to do.
I've a CUCM (8.6 version).
Best regards.
02-10-2015 01:31 AM
Try this..
Choose the server where the Cisco CallManager service runs, and then choose the Cisco CallManager service.
In Clusterwide Parameters (Device - General) change the parameter value of Always Display Original Dialed Number to true. The default setting is false.
02-10-2015 02:04 AM
Sorry but i don't see Service and Service Parameters in the the Cisco Unified CallManager Administration page.
Have an idea of the problem?
02-10-2015 02:13 AM
Oh Sorry its System>service parameters
02-10-2015 02:27 AM
Ok excuse me, l change the parameter value of Always Display Original Dialed Number to true, and restarted CM service, but the problem is the same.
02-10-2015 02:37 AM
OK..Please go to the translation pattern. Scroll down to the "Connected Party Transformations" page and change Connected Line ID Presentation to "restricted"
Test again
02-10-2015 03:14 AM
I put the fields to "Restricted" I could see the displayed good number but I did not see the "Alterning Name" corresponding to 9002.
To solve this problem, I deleted all translations pattern and I did a "Forward all" on the 9002 number to my external number.
Calling on the phone I see the "Alerting Name" field of the 9002 number.
