12-15-2014 06:24 AM - edited 03-17-2019 01:19 AM
Hello Everybody,
I have Aa CUCM 10.5 installed, and i need to change the default-language of a DX80 inside my cluster to French,
Someon know , how can i do that?
Thx in advance
Solved! Go to Solution.
12-15-2014 07:33 AM
The default language is set in System/Enterprise Parameters in CUCM.
You'll need to ensure you have installed the French locale file on all your CUCM server in the cluster.
Aaron
12-15-2014 07:36 AM
If you need to change locale to DX80 only, on phone configuration page, change the value User Locale if you previously installed French locale as correctly suggested by my buddy Aaron + 5 :)
Carlo
12-15-2014 07:33 AM
Aaron
12-15-2014 07:36 AM
Carlo
12-15-2014 08:56 AM
Thanks!
we are about to install the combined newtork file and locale french file. Then we will see...
