Change from 4 to 10 digit dialing
Cindy_Shu
Hi All,
I have a general question that I am hoping someone can offer help with.
We have 8 sites that are currently on 4 digit dialing.  I would like to change them to 10 digit dialing.  What is the general process for doing this? What all is involved?
Is there any documentation available on this?  Any best practices?
Cindy
3 Accepted Solutions
Jaime Valencia
The best document you can read is the dial plan section from SRND
Dial Plan
It really depends on what you want to do, change the actual DNs, make them E.164, just translate from 10 digit dialing to an actual 4 digit DN.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
A lot of people are going with E164 right now, features like EMCC and new features in 8.X require it.
If you don't need any of those and don't want to modify the DNs then just use TPs.
java
java
rcrumm_2
Level 2
Level 2
Hi here are a couple of things to consider.
You would have to change all the DN's. You would have to change your voicemail extensions
You would have to ensure what you receive from the PSTN could be routed to the correct phones
Hth
Randall
5 Replies 5
Jaime Valencia
Dial Plan
java
java
Thanks Java.
Between changing the DN versus using the translation rule, which one is usually preferred?
Shu
java
java
rcrumm_2
Level 2
Level 2
Hth
Randall
