Changing CUCM IP address
davistw
I am running CUCM 7.1.3a on a 2 node system (1 publisher and 1 subscriber). I need to move the publisher and the subscriber to different IP addreses.
What is the easiest way to do this?
I think I know how to physically change the IP on the publisher and subscriber  but wont that mess up the subscriber? Will I have to tear down the subscriber and reconnect it to the publsher after the ip change?
thank you for your help in advance.
Here are 2 links
1) All the 7.1 docs
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/docguide/7_1_3/dg713.html
2) Change ip address doc
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/7_1_2/ipchange/ipchg712.html
Yes 7.1.3 uses the same docs as 7.1.2
+5 to Aaron & Bill
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
9 Replies 9
Aaron Harrison
RTFM and all will be fine :
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/8_6_1/ipchange/ipchg861.html
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thanks for your reply, However, this is for 8.0 and later. I am running 7.1.3a as stated in the question, If you could  point me to the FM for 7.1.3a i would greatly appreciate it.
Aaron, good link and I love RTFM!  +5 to you brother.
davistw here is a version of the procedure for 7.1. It is is 7.1(2) but it applies to 7.1.3 as well:
www.cisco.com/en/US/docs/voice_ip.../cucm/.../7.../ipchg712.html
For future reference, I found the above via google search phrase:
"change IP address" + cucm + 7.1 site:cisco.com
Personally, I find that searching Cisco's site from google.com using the site:cisco.com option is much easier than CCO's search tool. Could be I am biased.
HTH.
-Bill (http://ucguerrilla.com)
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Not at all - want info from the Internet? Ask Google.
Want info from celebrities? Ask Oprah.
Just the way of the world!
Thanks Bill, I guess I had never thought out useing Google to search the Cisco site specificly. Thanks for the most excellent tip!!!!!
William finally i found someone who shares what I have always thought. It is easier to find cisco related stuff on google than on CCO! I concur 100%. I wonder why..........................
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Yeah - first time I saw google, it was shown to me by a guy from Cisco with the words 'this site seems to find a lot of stuff on our site'. It was just another search engine back then :-)
Here are 2 links
1) All the 7.1 docs
+5 to Aaron & Bill
Alex.
Excellent Alex.... Thanks you very much!!!!!
