ā12-29-2010 10:58 AM - edited ā03-16-2019 02:37 AM
hello,
I just configured E1 on my router to connect with local telco switch by configuring following parameters;
controller E1 0/0/1
pri-group timeslots 1-30
description FMX_HUB
interface Serial0/0/1:15
description FMX_HUB
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn timer T310 120000
isdn overlap-receiving
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
And after applying above mentioned configuration I got following status on E1 Controller
E1 0/0/1 is up.
Applique type is Channelized E1 - balanced
Cablelength is Unknown
Description: FMX_HUB
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20100222, FPGA: 13, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
but i am unable to make any call to PSTN dial-peers are properly configured and up and running for other E1s. debug output is
HUB-CORE#debug isdn q921
*Dec 29 09:35:54.987: ISDN Se0/0/1:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 29 09:35:55.987: ISDN Se0/0/1:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 29 09:36:01.987: ISDN Se0/0/1:15 Q921: L2_EstablishDataLink: sending SABME
*Dec 29 09:36:01.987: ISDN Se0/0/1:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 29 09:36:02.987: ISDN Se0/0/1:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 29 09:36:03.987: ISDN Se0/0/1:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 29 09:36:04.987: ISDN Se0/0/1:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 29 09:36:10.987: ISDN Se0/0/1:15 Q921: L2_EstablishDataLink: sending SABME
*Dec 29 09:36:10.987: ISDN Se0/0/1:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 29 09:36:11.987: ISDN Se0/0/1:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 29 09:36:12.987: ISDN Se0/0/1:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 29 09:36:13.987: ISDN Se0/0/1:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 29 09:36:19.987: ISDN Se0/0/1:15 Q921: L2_EstablishDataLink: sending SABME
*Dec 29 09:36:19.987: ISDN Se0/0/1:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 29 09:36:20.987: ISDN Se0/0/1:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 29 09:36:21.987: ISDN Se0/0/1:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 29 09:36:22.987: ISDN Se0/0/1:15 Q921: User TX -> SABMEp sapi=0 tei=0
HUB-CORE#debug isdn q931
debug isdn q931 is ON.
*Dec 29 09:36:50.987: ISDN Se0/0/1:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Dec 29 09:36:59.987: ISDN Se0/0/1:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Dec 29 09:37:08.987: ISDN Se0/0/1:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Dec 29 09:37:17.987: ISDN Se0/0/1:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Dec 29 09:37:26.987: ISDN Se0/0/1:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Dec 29 10:22:40.019: %MARS_NETCLK-3-HOLDOVER: Exiting Holdover for Controller E1 0/0/1
now help me to find the problem.
ā12-29-2010 11:30 AM
Hi Faheem,
hope everything is well.
why you configur encapsulation under the serial interface?
B.R./Haitham
If this helps, Please Rate
ā12-29-2010 11:42 AM
Please note: Whatever encapsulation is configured, or not configured, under a voice serial interface, will not make any difference.
The OP problem is caused by the fact that telco has not completed the provisioning, or the circuit is faulty. Nothing related to the router.
ā12-29-2010 11:51 AM
I would also check to see if you should indeed be emulating the network (unde the serial interface). Usually if you are going directly to the Telco switch, they are network. Regardless, we should be Tx and Rx SAMBE messages, i.e.:
*Dec 29 19:39:05.841: ISDN Se0/1/0:15 Q921: Net TX -> RRp sapi=0 tei=0 nr=60
*Dec 29 19:39:05.841: ISDN Se0/1/0:15 Q921: Net RX <- RRp sapi=0 tei=0 nr=66
*Dec 29 19:39:05.841: ISDN Se0/1/0:15 Q921: Net TX -> RRf sapi=0 tei=0 nr=60
*Dec 29 19:39:05.845: ISDN Se0/1/0:15 Q921: Net RX <- RRf sapi=0 tei=0 nr=66
ā12-29-2010 11:53 AM
May I nitpick again? Not usually, but always.
ā12-30-2010 09:32 AM
when i tried to initiate call i got follwoing messages on debug
*Dec 30 12:54:41.507: ISDN Se0/0/0:15 Q921: Net TX -> RRp sapi=0 tei=0 nr=37
*Dec 30 12:54:41.519: ISDN Se0/0/0:15 Q921: Net RX <- RRp sapi=0 tei=0 nr=37
*Dec 30 12:54:41.519: ISDN Se0/0/0:15 Q921: Net TX -> RRf sapi=0 tei=0 nr=37
*Dec 30 12:54:41.583: ISDN Se0/0/0:15 Q921: Net RX <- RRf sapi=0 tei=0 nr=37
*Dec 30 12:54:48.011: ISDN Se0/0/0:15 Q921: Net RX <- INFO sapi=0 tei=0, ns=37 nr=37
*Dec 30 12:54:48.011: ISDN Se0/0/0:15 Q921: Net TX -> RR sapi=0 tei=0 nr=38
*Dec 30 12:54:48.011: ISDN Se0/0/0:15 **ERROR**: Ux_BadMsg: Invalid Message for call state 6, call id 0x1E, call ref 0x8002, event 0x7B
*Dec 30 12:54:48.015: ISDN Se0/0/0:15 Q921: Net TX -> INFO sapi=0 tei=0, ns=37 nr=38
*Dec 30 12:54:48.043: ISDN Se0/0/0:15 Q921: Net RX <- INFO sapi=0 tei=0, ns=38 nr=37
*Dec 30 12:54:48.043: ISDN Se0/0/0:15 Q921: Net TX -> RR sapi=0 tei=0 nr=39
*Dec 30 12:54:48.047: ISDN Se0/0/0:15 **ERROR**: Ux_BadMsg: Invalid Message for call state 6, call id 0x1E, call ref 0x8002, event 0x7B
*Dec 30 12:54:48.047: ISDN Se0/0/0:15 Q921: Net TX -> INFO sapi=0 tei=0, ns=38 nr=39
*Dec 30 12:54:48.075: ISDN Se0/0/0:15 Q921: Net RX <- INFO sapi=0 tei=0, ns=39 nr=37
*Dec 30 12:54:48.075: ISDN Se0/0/0:15 Q921: Net TX -> RR sapi=0 tei=0 nr=40
*Dec 30 12:54:48.075: ISDN Se0/0/0:15 **ERROR**: Ux_BadMsg: Invalid Message for call state 6, call id 0x1E, call ref 0x8002, event 0x7B
*Dec 30 12:54:48.079: ISDN Se0/0/0:15 Q921: Net TX -> INFO sapi=0 tei=0, ns=39 nr=40
*Dec 30 12:54:48.211: ISDN Se0/0/0:15 Q921: Net RX <- RR sapi=0 tei=0 nr=38
*Dec 30 12:54:48.363: ISDN Se0/0/0:15 Q921: Net RX <- RR sapi=0 tei=0 nr=39
*Dec 30 12:54:48.511: ISDN Se0/0/0:15 Q921: Net RX <- RR sapi=0 tei=0 nr=40
*Dec 30 12:54:51.527: ISDN Se0/0/0:15 Q921: Net RX <- RRp sapi=0 tei=0 nr=40
*Dec 30 12:54:51.531: ISDN Se0/0/0:15 Q921: Net TX -> RRf sapi=0 tei=0 nr=40
*Dec 30 12:55:01.527: ISDN Se0/0/0:15 Q921: Net TX -> RRp sapi=0 tei=0 nr=40
*Dec 30 12:55:01.539: ISDN Se0/0/0:15 Q921: Net RX <- RRp sapi=0 tei=0 nr=40
*Dec 30 12:55:01.539: ISDN Se0/0/0:15 Q921: Net TX -> RRf sapi=0 tei=0 nr=40
*Dec 30 12:55:01.607: ISDN Se0/0/0:15 Q921: Net RX <- RRf sapi=0 tei=0 nr=40
*Dec 30 12:55:11.547: ISDN Se0/0/0:15 Q921: Net RX <- RRp sapi=0 tei=0 nr=40
*Dec 30 12:55:11.547: ISDN Se0/0/0:15 Q921: Net TX -> RRf sapi=0 tei=0 nr=40
and no call in the end
ā12-30-2010 12:51 PM
Now you have to look at "show isdn status", should be multiframe established.
Then, you disable debug isdn q921, and enable q931 instead.
ā01-01-2011 11:57 AM
Problems has been resolved now, but i have to wait for some time after dialing a number to establish a call.. every this is fine with E1, no errors on L2 or L3 but when i enable Debug ISDN Q931 following logs display on my screen...
Router_HUB#
*Jan 1 14:50:52.535: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0359
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98399
Exclusive, Channel 25
Calling Party Number i = 0x0181, '202786'
Plan:ISDN, Type:Unknown
High Layer Compat i = 0x9181
*Jan 1 14:50:52.539: ISDN Se0/0/0:15 EVENT: process_rxstate: ces/callid 1/0x11 calltype 2 CALL_INCOMING
*Jan 1 14:50:52.539: ISDN Se0/0/0:15 EVENT: call_incoming: call_id 0x0011, Guid = 5D3FF4988016
*Jan 1 14:50:52.543: ISDN Se0/0/0:15 Q931: TX -> SETUP_ACK pd = 8 callref = 0x8359
Progress Ind i = 0x8188 - In-band info or appropriate now available
*Jan 1 14:50:52.571: ISDN Se0/0/0:15 Q931: RX <- STATUS pd = 8 callref = 0x0359
Cause i = 0x81E31E - Information element not implemented
Call State i = 0x02
*Jan 1 14:50:53.531: ISDN Se0/0/0:15 Q931: RX <- INFORMATION pd = 8 callref = 0x0359
Called Party Number i = 0x81, '2'
*Jan 1 14:50:53.531: ISDN Se0/0/0:15 EVENT: process_rxstate: ces/callid 1/0x11 calltype 2 CALL_INFO
*Jan 1 14:50:54.231: ISDN Se0/0/0:15 Q931: RX <- INFORMATION pd = 8 callref = 0x0359
Called Party Number i = 0x81, '0'
*Jan 1 14:50:54.231: ISDN Se0/0/0:15 EVENT: process_rxstate: ces/callid 1/0x11 calltype 2 CALL_INFO
*Jan 1 14:50:54.419: ISDN Se0/0/0:15 Q931: RX <- INFORMATION pd = 8 callref = 0x0359
*Jan 1 14:50:54.419: ISDN Se0/0/0:15 EVENT: process_rxstate: ces/callid 1/0x11 calltype 2 CALL_INFO
*Jan 1 14:51:08.447: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x0359
Cause i = 0x8190 - Normal call clearing
*Jan 1 14:51:08.447: ISDN Se0/0/0:15 EVENT: process_rxstate: ces/callid 1/0x11 calltype 2 CALL_DISC
*Jan 1 14:51:08.451: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x8359
*Jan 1 14:51:08.475: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0359
*Jan 1 14:51:08.475: ISDN Se0/0/0:15 EVENT: process_rxstate: ces/callid 1/0x11 calltype 2 CALL_CLEARED
