Cisco 2900 ISR CME Licenses
nomykhan
I just need to check if i purchase the Cisco CME for 2900/3900... Do i also need to purchase CME licenses for the phones? i mean this part number
SW-CCM-UL-7942    CUCM 3.x or 4.x RTU lic. for single IP Phone 7942
Leaally i know it should be purchased.....but from the implementation perspective does the CME keeps any check on the router for these license? like the DLUs in CUCM?
Nouman
paolo bevilacqua
As you could have found using the search function:
CME (any version) does not enforce phones licenses in any way.
5 Replies 5
Faheem Ansari
Salam Nouman,
as per my experience, you dont require any additional IP Phone licenses but You must purchase a base Cisco Unified CME feature license and phone user licenses that entitle you to use Cisco Unified CME.
by the way what is the version of your CME?
Faheem Ansari
paolo bevilacqua
Thanks.
Yeah enforcement was my main concern.
Thank you for the nice rating and good luck!
hi,
i need to check if i buy a cisco2901-v/k9 that have voice license i will have telephony-service and can configure all the phones that the hardware permit without any aditional license like dlu for the phones?
or i have to buy c2901-cme-srst/k9 that have voice license and 25 license for phones ??
thanks for the answers !
