05-04-2018 12:53 AM - edited 03-17-2019 12:44 PM
Hi Cisco Community Support,
We have an issue where internally forwarded calls to external are not receiving RTP, this was rectified by using the following commands:
voice service voip
media anti-trombone
However, even after having saved the configuration the command appears to disable itself after a reboot and has to be re-applied.
The device is a 2901.
The IOS version is: 151-4-M4
Can anyone confirm as I have looked through the documentation on this but have failed to find anywhere that explicitly defines that this command is dropped upon reboot.
Any help will be greatly appreciated.
Christopher
05-04-2018 03:20 AM
05-04-2018 11:55 PM - edited 05-04-2018 11:55 PM
Thank you for the prompt response, if the IOS is upgraded will we need to re-host the license at all to support that version?
Christopher
05-05-2018 01:30 AM
05-09-2018 05:05 AM
