Cisco 3905 problem / remote site
Hi all!
Information:
I have CUCM 8.6.2.20000-2 and many Cisco IP Phone 3905 (SIP). Some of them deployed in central office and some in remote sites.
Phone information:
Boot Version: 3905.0-0-0-01-01
DSP Version: 12.0.0.8
Application: 3905.9-2-2-0
Symptoms:
In remote sites only!
The phone is registered and working fine. However, after few hours idle state I lift the handset, dial any number and nothing happens. Drop the call and try again 2-3 times. After that either call passed or get permanent busy tone (need to reboot the phone to work again).
The phone is marked as registered on CUCM and I hear dial tone when lifted the handset.
I cannot collect debug messages from phones, because as soon as I login via telnet it going work fine.
There is no such problem in central office.
Phones print following messages in terminal all the time:
17:07:10:302 x [CENTRAL] CDP/LLDP-MED CB function is called
17:07:26:491   [sip]  03:58:24.490    pjsua_acc.c  SIP outbound status for acc 0 is not active
17:07:26:495   [sip]  03:58:24.494    pjsua_acc.c  "п°п╦я┘п╟п╦п╩ п я┐пЇя▄п╪п╦пҐ"<sip:7102@192.168.13.50:5060>: registration success, status=200 (OK              ), will re-register in 120 seconds
17:07:26:502   [sip]  03:58:24.500         pjcu.c  pjcu_on_reg_state2(), Account["п°п╦я┘п╟п╦п╩ п я┐пЇя▄п╪п╦пҐ"<sip:7102@192.168.13.50:5060>] : OK,               status=200
17:07:26:506 x [pcu] pcuRcvHandler(CALL), SRV_EV, eid=0, cid=65535,
17:07:26:510 x [pcu] [pcux_insrv_cb():7071] CUCM_DateTime:Mon, 27 May 2013 11:07:26 GMT
17:07:26:511 x [pcu] Sync time from server: Mon, 27 May 2013 11:07:26 GMT
17:07:26:515 x [pcu] [set_svr_type][1599] Bfe active_server_idx=0, serverType=0
17:07:26:515 x [pcu] [set_svr_type][1602] Aft  serverType=0, Server Number=2
17:07:26:531   [ipps] ----- PCU: CC_SRV, pid=0, eid=0, cid=65535 -----
17:07:26:532   [ipps] In func: remoteNtyEvtProcess(), lib = 0, cid = 65535, ntyEv = 0
17:07:26:533 f [ipps] In func: remoteNtyEvtProcess(), recv inservice nty, svrType = 0, cause = 0
17:07:26:534 f [MMI] <RCV>: In func: ui_nty(), lid = 0, cid = 65535, ntyEv = 0
17:07:26:535 x [CENTRAL] IPPS CB function(RegStatus) is called (1) with Line (0)
17:07:26:536 f [ipps] In func: mlcu_isKpmlEnabled(), KPML value = 3, blRet = 1
17:07:26:537 x [CENTRAL] Enter FSM: State(STANDBY) | Event(REGISTER_OK) | Cause(0)
17:07:26:540 x [CENTRAL] Unexpected event REGISTER_OK (cause=0) at STANDBY state
17:07:26:541 x [CENTRAL] Waiting event in STANDBY
17:07:58:990 x [CENTRAL] CDP/LLDP-MED CB function is called
17:08:39:022   [sip]  03:59:37.021         pjcu.c  pjcuRcvHandler(KA), KA_REQUEST, eid=-1, p1=192.168.70.1:5060
17:08:39:040   [sip]  03:59:37.036         pjcu.c  pjcu_rpt_ka_status(), target(192.168.70.1:5060): status=1, id=27
17:08:39:044 x [pcu] pcuRcvHandler(KA), KA_RESPONSE, eid=0, addr=192.168.70.1:5060, status=1
17:08:39:050 x [pcu] [pcu_polling_sipserver_thread():1478] mark!
17:08:54:130 x [CENTRAL] CDP/LLDP-MED CB function is called
Thanks for your help.
18 Replies 18
Anybody found solution to this issue? we are facing similar issue on 3905, from our remote sites we have to dial 3-4 times to make a call while other handsets models are working fine.
After rebooting 3905 phone works fine but after sometime again same issue appears.
Please suggest if someone solved this issue. Thanks.
amansin74
Hi F.rowan,
What kind of debug outputs are you getting for debug ccsip messages.
can you post here? it will be useful to all .
Aman
“If you have knowledge, let others light their candles in it.”
Please try to upgrade to the latest available firmware, 9.4(1), and try again.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
dferrat
I have the same problem, still no solution?
