Cisco 6941 phones are showing Incorrect Time
Syed Mohammed
We have 6941,7945,7975 phones which is registered on CME (10.5). 7945,7975 phones are showing correct time as we set, but 6941 phones showing incorrect time (3 hour before).
6941 phone firmware is (Sccp-9-4-1-3SR1) and we have downgrade to (9-3-3-2-SR1) but issue is still persisting.
Syed
6 Replies 6
Suresh Hudda
Does all 6941 phones showing incorrect time ? can you try to factory reset one of these phone and see. Suresh
Yes. All 6941 phones are showing incorrect  time. If we are doing factory reset phone is showing upgrading till we unplug the phone.
Syed
Do you have the type command under the ephone configuration?
Please rate all useful posts
Yes. Please check below
ephone 1
mac-address 649E.F36D.A609
max-calls-per-button 2
type 6941
button 1:1
Syed
Syed,
Can you send us your sh run. Do you have the time-zone configured?
Yes. I have configured time-zone. Please check below.
clock timezone GMT 2 0
clock summer-time DST recurring 2 Wed Apr 12:50 1 Wed Dec 12:50 180
clock calendar-valid
tftp-server flash:BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:DSP69xx.12-4-122-99.131025.zz.sgn
tftp-server flash:SCCP69xx.9-4-1-3SR2.loads
tftp-server flash:SCCP69xx.9-4-1-3SR2.zz.sgn
tftp-server flash0:B016-1-0-4-2
tftp-server flash:B016-1-0-4-2.SBN
tftp-server flash:TZDataCSV.csv
tftp-server flash:tzupdater.jar
telephony-service
max-ephones 50
max-dn 250
ip source-address port 2000
auto assign 1 to 45
system message
cnf-file location flash:
load 7916-24 B016-1-0-4-2
load 6941 SCCP69xx.9-4-1-3SR2
olsontimezone SA version 2010o
time-zone 31
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
multicast moh 239.1.1.1 port 2000
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Apr 06 2016 13:00:40
Syed
