Cisco IP communicator with two wireless headsets
MikkoP
I use the Cisco IP Communicator 8.6.6.0 and I have two Plantronics Voyager Focus UC wireless headsets.
I need to connect both headsets to the IP communicator, so that one person can take calls with one pair and another person can listen to the calls. Similiarly what one would do with the Y-splitter cable and a physical IP phone.
Is there any way to do this with the Cisco IP Communicator?
in some occasions (this will depend on the audio drivers/tools on the client)
in Communicator you may be able to select "audio mixer" as output device instead of headphone or speakers
then in the mixer you may be able to select two headphones as output and adjust the volume
give it a try, you'll never know....
this link discusses a tool called audio router
this link discusses microsoft stereo mix
Chris Deren
I don't see how that would be possible.
George Sotiropoulos
It seems that there is no way to implement this, since on the Audio Preferences you can select just one audio source.
Hope the above helps,
gsotirop
