Cisco 7821 Parse Error [4] when accessing Corporate Directory
richb1971
Level 4
Level 4
Unable to access Corporate Directory, softkey template has changed (DND has appeared) and speakerphone volume slide bar doesn't display.
This happens intermittently on different phones and temporarily disappears if unplugged.
CUCM Version:System version: 10.0.1.10000-24
Phone firmware:sip78xx.10-1-1-9
Any suggestions?
Rich
17 Replies 17
Hello guys!
I'm facing the same issue here with some CP-7821 phones.
When a search is made in the corporate directory, the users receive a "XML parser error"
I do believe that this problem is related to this bug CSCse37151
https://tools.cisco.com/bugsearch/bug/CSCse37151
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-ip-phone-7900-series/100895-xml-parse-error.html
The AD catalog has more than 10 thousands accounts and I can not edit them.
Currently we are using these versions:
CCM 9.1.2.10000-28
Phone load: sip78xx.10-1-1SR2-1
Please, I'd like to know if this firmware sent by TAC worked or not.
Thank you in advance.
Hello Edson !
                          Yes , it resoled the issued , However i suggest to to apply on
one test phone , then apply to all..
Thanks.
SHIB
Hi Scott ,
             The probem resolved by this firmware .Please upload thorigh TFTP management . then upload on one phone before all .
SHIB
