Cisco 7821 phones
 - CUCM Version 9.1.2.
 - Newly deployed Cisco 7821 phones in cluster
 - facing issue with registration, showing UNKNOWN for some of the phones
 - if I reset the registered phone taking 30 min to register again
 - even if i update the Line page, its taking 30 mins to register
 - TFTP is not responding to the phone request for the file j9-tzdata.jar.sgn
 - Any idea regarding this issue
24 Replies 24
Pls check the attachment.
Th
You don't need to upgrade it , you just need to upload it.
Go to the TFTP file management option under software upgrade and once you click on upload file a small window will pop up asking to browse that file locally from the machine and select the directory as "/".
Hey Manish,
The same problem :(
Did you went through the steps that i mentioned above ? which error did you get when you selected the file and click on upload file ?
Can you walk through the steps that you using while uploading this file ?
Hii,
I upload the file and I don't receive any error, I restart the TFTP and CallManger and the problem is still on.
I check on TFTP and I don't find the file with the name:
 j9-tzdata.jar.sgn
The Phone still restarting and register and restart :(
Can you capture the console messages of phone and also the TFTP traces from cucm and attach it here.
Hi ,
In addition to what Manish has said, from CLI you run run the command file list tftp *tzdata* and check whether file has been uploaded or not.
regds,
aman
Hey,
The same problem, I add the Phone to another CUCM and it's working fine, in my opinion is something with the trust between the CUCM and the Phone:(
I dont now how to check or what I have to check, any ideas?
Yours isn't registering due to CUCM sending a 404 Not Found in response to the Register:
8147 DEB 11:48:57.030857 JAVA: sipio-recv<--- SIP/2.0 404 Not Found^M
	Via: SIP/2.0/TCP 10.217.201.250:50132;branch=z9hG4bK71f03325^M
	From: <sip:2626@10.217.196.5>;tag=2c3ecf87fe2700104fe266e5-636da9bd^M
	To: <sip:2626@10.217.196.5>;tag=2125053026^M
	Date: Tue, 10 Jun 2014 08:48:57 GMT^M
	Call-ID: 2c3ecf87-fe270020-3b4292a0-6952da07@10.217.201.250^M
	CSeq: 106 REGISTER^M
	Warning: 399 RO-TM-SUB-01 "Database error"^M
	Content-Length: 0^M
Make sure that all nodes have the device pack installed and have been rebooted.  Make sure that dbreplication is okay by running "utils dbreplication runtimestate" from publisher.
Make a new post for your issue so it can be tracked easier.
Restart the Cluster again and it works ( no comment).
