Cisco 7936 load fail
ericdegboevi
I have a CME 3.3 configured and working.
I downloaded the file "cmterm_7936.3-3-5-0.bin" when i load it on the router i have the message "cmterm_7936.3-3-5-0 does not exist.
When i reboot the cisco 7936 it could not load the file and using the firmware for 7960.
The result is that the voice is not clair
my IOS is "Version 12.4(3c)"
Can you help?
Looks like the phone has successfully loaded the new firmware and I hope that fixes the issue you were having. You are welcome to rate this post if you want.
paolo bevilacqua
Hi Eric,
assuming you copy the file in the main directory, you will configure;
tftp-server flash:/cmterm_7936.3-3-5-0.bin alias cmterm_7936.3-3-5-0.bin
telephony-service
load 7935 cmterm_7936.3-3-5-0.bin
Then, please type 'debug tftp event' and terminal monitor'. restart the phone and observe the booting process. If it fails upgrading code, post the above output here.
Hi Bevilacqua,
It work like magic
Thanks a lot.
I have attached the debug output though.
Eric
