Cisco 7960 SIP Phones are registered with CME but its not accepting proxy server IP address.
Anupam Singh
Cisco 7960 Sip phones are registered with CME on Cisco 2911 Router. But if I try to register ip phones with sip proxy server it is not accepting  proxy ip address. As it it using 'Usecallmanager' for registering phones. When I try to change ip setting in SIPDefault.cnf. It automatically revert back to Usecallmanager for registering phones.
Can Anyone suggest solution please so that I could register phones with sip proxy server ip.
CME#more SIPDefault.cnf
image_version: "P0S3-08-9-00";
call_manager1_addr: "10.15.1.1";
call_manager2_addr: "";
call_manager3_addr: "";
call_manager4_addr: "";
call_manager1_sip_port: "5060";
call_manager2_sip_port: "";
call_manager3_sip_port: "";
call_manager4_sip_port: "";
proxy1_address: "USECALLMANAGER";
proxy2_address: "";
proxy3_address: "";
proxy4_address: "";
proxy5_address: "";
proxy6_address: "";
proxy1_port: "5060";
proxy2_port: "";
proxy3_port: "";
proxy4_port: "";
proxy5_port: "";
proxy6_port: "";
proxy_register: "1";
time_zone: "PST";
dst_auto_adjust: "1";
 dst_start_month: "April";
dst_start_day: "";
dst_start_day_of_week: "Sun";
dst_start_week_of_month: "1";
dst_start_time: "02:00";
dst_stop_month: "October";
dst_stop_day: "";
dst_stop_day_of_week: "Sun";
dst_stop_week_of_month: "8";
dst_stop_time: "02:00";
date_format: "M/D/Y";
time_format_24hr: "0";
local_cfwd_enable: "1";
directory_url: "";
messages_uri: "";
services_url: "http://10.15.1.1:80/CMEserverForPhone/serviceurl";
logo_url: "";
stutter_msg_waiting: "0";
sync: "0004723960543944";
telnet_level: "0";
autocomplete: "1";
call_stats: "0";
Domain_Name: "";
dtmf_avt_payload: "101";
 --More--         dtmf_db_level: "3";
dtmf_inband: "1";
dtmf_outofband: "avt";
dyn_dns_addr_1: "";
dyn_dns_addr_2: "";
dyn_tftp_addr: "";
end_media_port: "32766";
http_proxy_addr: "";
http_proxy_port: "80";
nat_address: "";
nat_enable: "0";
nat_received_processing: "0";
network_port2_type: "Hub/Switch";
CME#sh voice register global
CONFIG [Version=8.6]
  Version 8.6
  Mode is cme
  Max-pool is 10
  Max-dn is 20
  Outbound-proxy is enabled and will use global configured value
  Security Policy: DEVICE-DEFAULT
  Forced Authorization Code Refer is enabled
  Source-address is 10.15.1.1 port 5060
  Load 7960-40 is P0S3-08-9-00
  Authenticate register
  Authenticate realm all
  Time-format is 12
  Date-format is M/D/Y
  Time-zone is 5
  Hold-alert is disabled
  Mwi stutter is disabled
  Mwi registration for full E.164 is disabled
  Forwarding local is enabled
  Video is disabled
  Camera is disabled
  Privacy is enabled
  Privacy-on-hold is disabled
  Dst auto adjust is enabled
    start at Apr week 1 day Sun time 02:00
    stop  at Oct week 8 day Sun time 02:00
  Call List BLF is enabled
  Max redirect number is 5
  IP QoS DSCP:
    ef (the MS 6 bits, 46, in ToS, 0xB8) for media
    cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
    af41 (the MS 6 bits, 34, in ToS, 0x88) for video
    default (the MS 6 bits, 0, in ToS, 0x0) for service
  Telnet Level: 0
  Tftp path is flash:
  Generate text file is disabled
  Tftp files are created, current syncinfo 0004723960543944
   timeout interdigit 10
  network-locale[0] GB    (This is the default network locale for this box)
  network-locale[1] GB
  network-locale[2] GB
  network-locale[3] US
  network-locale[4] US
  user-locale[0] US    (This is the default user locale for this box)
  user-locale[1] US
  user-locale[2] US
  user-locale[3] US
  user-locale[4] US   Active registrations  : 3
  Total SIP phones registered: 3
  Total Registration Statistics
    Registration requests  : 6
    Registration success   : 3
    Registration failed    : 3
    unRegister requests    : 0
    unRegister success     : 0
    unRegister failed      : 0
    Attempts to register
           after last unregister : 0
    Last register request time   : 21:32:05.035 UTC Tue Aug 19 2014
    Last unregister request time :
    Register success time        : 21:32:05.039 UTC Tue Aug 19 2014
    Unregister success time      :
CME#sh voice register pool all
 Pool Tag 1
Config:
  Mac address is 0003.6B54.BCD9
  Type is 7960
  Number list 1 : DN 1
  Proxy Ip address is 0.0.0.0
  Current Phone load version is Cisco-CP7960G/8.0
  DTMF Relay is enabled, sip-notify
  Call Waiting is disabled
  DnD is disabled
  Video is disabled
  Camera is disabled
  Busy trigger per button value is 0
  keep-conference is enabled
  registration expires timer max is 3600 and min is 3600
  username 5000 password 123abc!
  Lpcor Type is none
  Transport type is udp
  service-control mechanism is supported
  registration Call ID is 00036b54-bcd90002-7d9c5274-07362b91@10.15.1.11
  Registration method: per line
  Privacy feature is not configured.
  Privacy button is disabled
  active primary line is: 5000
  contact IP address: 10.15.1.11 port 5060
Dialpeers created:
Dial-peers for Pool 1:
dial-peer voice 40002 voip
 destination-pattern 5000
 session target ipv4:10.15.1.11:5060
 session protocol sipv2
 dtmf-relay sip-notify
 codec  g711ulaw bytes 160
  call-fwd-busy        5002
  after-hours-exempt   FALSE
Statistics:
  Active registrations  : 1
    Registration requests  : 1
    Registration success   : 1
    Registration failed    : 0
    Last register request time   : 21:31:57.883 UTC Tue Aug 19 2014
    Register success time        : 21:31:57.887 UTC Tue Aug 19 2014
 Pool Tag 3
Config:
  Mac address is 0002.B9AF.C0F7
  Type is 7960
  Number list 1 : DN 3
  DnD is disabled
  Video is disabled
  Camera is disabled
  username 5002 password 123abc!
  Lpcor Type is none
  registration Call ID is 0002b9af-c0f70002-65fcb4a6-2907265f@10.15.1.12
  active primary line is: 5002
  contact IP address: 10.15.1.12 port 5060
Dialpeers created:
Dial-peers for Pool 3:
dial-peer voice 40001 voip
 destination-pattern 5002
 session target ipv4:10.15.1.12:5060
  call-fwd-busy        5003
Statistics:
    Last register request time   : 21:31:55.803 UTC Tue Aug 19 2014
    Register success time        : 21:31:55.803 UTC Tue Aug 19 2014
 Pool Tag 4
Config:
  Mac address is 0003.6B75.A91C
  Type is 7960
  Number list 1 : DN 4
  DnD is disabled
  Video is disabled
  Camera is disabled
  username 5003 password 123abc!
  Lpcor Type is none
  registration Call ID is 00036b75-a91c0002-7bab3ba2-4437ee75@10.15.1.13
  active primary line is: 5003
  contact IP address: 10.15.1.13 port 5060
Dialpeers created:
Dial-peers for Pool 4:
dial-peer voice 40003 voip
 destination-pattern 5003
 session target ipv4:10.15.1.13:5060
  call-fwd-busy        5000
Statistics:
I do welcome any suggestion from anyone.
13 Replies 13
problemchild27
      What is the firmware files has the IP Phone been loaded with? Make sure you use SIP based firmwares for the IP Phones.
Thankyou
      PC
This is running SIP firmware on all Cisco ip phones. All phones are registered as SIP using voice register global command. Regards
What do you mean by SIP proxy server here ? Do you want SIP phone to register with other sip proxy server but not with CME SIP ?
If yes when you change IP adress on phone to point it to a new proxy server other that CME , what error do you get ? Have enable packet capture on Phone lan interface to see where register request are going and also on SIP proxy server do you receive any request from phone?
Hi Manish,
Yes i would like to register with sip proxy server. following errors come when i try to change proxy server address on pools.
CME(config-register-pool)#voice register pool 1
CME(config-register-pool)#proxy 122.163.54.175
Failed: CME mode!
CME(config-register-pool)#voice register pool 2
Failed: CME mode!
if I try to remove cme mode by enabling 'no mode cme' in 'voice register global' mode then it removes the option of configuring proxy address on phones under 'voice register pool' command.
If you want 7960 to register with other proxy server , then change its tftp ip to 122.163.54.175 from the physical phone itself not from CME.
Here is the link.
its too difficult to change tftp server server on phone. Its not giving option to edit on phone even I follow the unlocking steps. I can edit all other configuration sip proxy server from phone, sip line setting etc but can not change network configuration. Its taking network configuration  frorm DHCP of router.
once I restart phone all configurations are revert back to same.
Change option 150 ip under dhcp pool to global ip.
Still not able to register with sip proxy server. please find show run output below.
Building configuration...
Current configuration : 10145 bytes
! Last configuration change at 18:10:04 UTC Thu Aug 21 2014
version 15.1
hostname RedoQCME
boot-start-marker
boot-end-marker
no aaa new-model
network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.1.1 10.10.1.10
ip dhcp excluded-address 10.15.1.1 10.15.1.10
ip dhcp pool DATA
 network 10.10.1.0 255.255.255.0
 default-router 10.10.1.1
ip dhcp pool VOICE
 network 10.15.1.0 255.255.255.0
 default-router 10.15.1.1
 option 150 ip 122.163.33.51
no ip domain lookup
ip name-server 78.143.192.10
ip name-server 78.143.192.20
isdn switch-type basic-net3
trunk group ext
voice-card 0
 codec complexity high
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
  h225 timeout ntf 500
  call preserve
  h245 caps mode restricted
 modem passthrough nse codec g711ulaw
 sip
  bind control source-interface GigabitEthernet0/1.15
  bind media source-interface GigabitEthernet0/1.15
  registrar server expires max 3600 min 3600
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 3
 mode cme
 source-address 10.15.1.1 port 5060
 max-dn 20
 max-pool 10
 load 7960-7940 P0S3-08-9-00
 authenticate register
 authenticate realm all
 call-forward system redirecting-expanded
 tftp-path flash:
 create profile sync 0004723960543943
 network-locale GB
 network-locale 1 GB
 network-locale 2 GB
voice register dn  1
 number 5000
 call-forward b2bua busy 5002
 allow watch
 name SIP 1
voice register dn  3
 number 5002
 call-forward b2bua busy 5003
 allow watch
 name SIP 3
voice register dn  4
 number 5003
 call-forward b2bua busy 5000
 allow watch
 name SIP 4
 id mac 0003.6B54.BCD9
 type 7960
 number 1 dn 1
 no call-waiting
 codec g711ulaw
voice register pool  3
 id mac 0002.B9AF.C0F7
 type 7960
 number 1 dn 3
 no call-waiting
 codec g711ulaw
voice register pool  4
 id mac 0003.6B75.A91C
 type 7960
 number 1 dn 4
 no call-waiting
 codec g711ulaw
voice hunt-group 1 sequential
 final 5003
 list 5000,5002
 timeout 20
 pilot 5900
license udi pid CISCO2911/K9 sn FCZ163379BR
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package uck9
license boot module c2900 technology-package datak9
hw-module pvdm 0/0
username redoq privilege 15 secret 4 RItztkF0kItnl6GrGfyp9UBfMwc6PeNSfVkMYePCEkY
redundancy
controller VDSL 0/1/0
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 1.1.1.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no ip address
 duplex auto
 speed auto
 encapsulation dot1Q 1
 ip address 10.1.1.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.10
 encapsulation dot1Q 10 native
 ip address 10.10.1.1 255.255.255.0
 ip nat inside
 encapsulation dot1Q 15
 ip address 10.15.1.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface BRI0/0/0
 no ip address
 isdn point-to-point-setup
 isdn incoming-voice voice
 isdn calling-number RedoQ
 isdn supp-service name calling
 isdn static-tei 0
interface BRI0/0/1
 no ip address
 isdn static-tei 0
interface ATM0/1/0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 no atm ilmi-keepalive
 pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Ethernet0/1/0
 no ip address
 no fair-queue
interface Dialer0
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication chap callin
 ppp chap hostname xxxxxxxxxxxxxxxx
 ppp chap password 0 redoqinfinity1
 no cdp enable
router eigrp 100
 network 10.0.0.0
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 36000 requests 10000
ip http path flash:
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source list 2 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 permit 1.0.0.0 0.255.255.255
access-list 2 permit 10.0.0.0 0.255.255.255
tftp-server flash:OS79XX.txt
tftp-server flash:P003-08-9-00.bin
tftp-server flash:P003-08-9-00.sbn
tftp-server flash:P0S3-08-9-00.loads
tftp-server flash:P0S3-08-9-00.sb2
control-plane
voice-port 0/0/0
 input gain 4
 compand-type a-law
 cptone GB
 timeouts call-disconnect 5
 timeouts wait-release 5
 connection plar 5900
 bearer-cap Speech
voice-port 0/0/1
 input gain 4
 compand-type a-law
 cptone GB
 bearer-cap Speech
voice-port 0/2/0
 supervisory disconnect dualtone pre-connect
 supervisory answer dualtone sensitivity high
 no battery-reversal
 soft-offhook
 input gain 4
 cptone GB
 connection plar opx 5000
 impedance complex2
 bearer-cap Speech
 caller-id enable
voice-port 0/2/1
 no battery-reversal
 soft-offhook
 input gain 4
 cptone GB
 impedance complex2
 bearer-cap Speech
 caller-id enable
mgcp profile default
dial-peer voice 1 pots
 description *** emergency 999 ***
 destination-pattern 999
 progress_ind setup enable 3
 progress_ind alert enable 8
 translate-outgoing called 10
 port 0/0/0
 forward-digits all
dial-peer voice 3 pots
 description ** E1 PRI pots dial-peer **
 destination-pattern 07412626634
 incoming called-number .
 no digit-strip
 direct-inward-dial
 port 0/0/0
dial-peer voice 11 pots
 port 0/0/1
 forward-digits all
dial-peer voice 31 pots
 no digit-strip
 direct-inward-dial
 port 0/0/1
dial-peer voice 100 pots
 description *** Services ***
 destination-pattern 0[1-6]T
 no digit-strip
 port 0/0/0
dial-peer voice 101 pots
 no digit-strip
 port 0/0/1
dial-peer voice 5999 voip
 description ** cue voicemail pilot number **
 destination-pattern 5999
 session target ipv4:10.15.1.2
 codec g711ulaw
dial-peer voice 9281 pots
 destination-pattern [2-8].....
 no digit-strip
 port 0/0/1
dial-peer voice 9282 pots
 no digit-strip
 port 0/0/0
dial-peer voice 800 pots
 description *** Customer Care Services ***
 destination-pattern 08.........
 no digit-strip
 port 0/0/0
dial-peer voice 801 pots
 description *** Customer Care Services Services ***
 no digit-strip
 port 0/0/1
dial-peer voice 1000 voip
 destination-pattern 5...
 codec g711ulaw
dial-peer voice 2001 voip
 codec g711ulaw
dial-peer voice 2002 voip
 session target ipv4:10.15.1.1:5060
 codec g711ulaw
dial-peer voice 2003 voip
 codec g711ulaw
dial-peer voice 2004 voip
 codec g711ulaw
presence
 presence call-list
sip-ua
 no remote-party-id
 retry invite 3
 retry register 3
 registrar ipv4:122.163.33.51 expires 3600
 sip-server ipv4:122.163.33.51
 host-registrar
gatekeeper
 shutdown
line con 0
 password
 login
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 exec-timeout 0 0
 privilege level 15
 password redoq123
 logging synchronous
 login local
 transport input all
 transport output all
scheduler allocate 20000 1000
ntp server 85.119.80.232
end
Manish,
I have got success to change tftp ip (network config)and proxy ip (sip line config) in ip phones only. I can receive calls on extensions from local trunk on router but not able to make calls on any extensions or outside network. it is showing CALLING ( OUT INV) on the phone. The status message on the phone are available in the image attached here.
It will really be helpful if you find any clue with these.
Now your phone is registered with outside proxy server , so in this case you will not able to call any CME extension from this SIP phone as you are no longer registered with CME. To achieve this you have to dial the whole pstn number for CME extensions so that external proxy server can route back call to you router.
Second , To troubleshoot outside external call from 7960 we need to see sip message exchange between 7960 to external sip proxy , enable packet capture on switchport where 7960 is connected and send across it.
I don't think you can do that.  CME is going to update those files automatically so you need to use another device for TFTP like a dedicated TFTP server if you want to push out manually updated configs.
Thats true. I tries doing change in config files using TFTP server but it still gone back to normal if I restart router or crearting profile in voice register global mode.
I really need to register phones with sip proxy server with a global ip address. Is it possible all phones gets network configurations from cme router but registering with another proxy server?
Anupam Singh
DO I need to configure Cisco Unified SRST(Survivable Remote Site Telephony) feature on it then it will register with outside proxy server?
I do welcome any type of suggestion
