12-14-2011 11:40 AM - edited 03-16-2019 08:32 AM
I recently bought 350 Cisco 7962s for UCM 7.X of those 350 about 100 of them I cannot access our corporate directory. I get an error saying to contact the administrator.
I have tried to do the factory reset; there are no Config differences between the phones that work and the phones that do not work, Same Firmware, Same Subnet, and same UCM Config, I know this for sure as I used the same bulk template for them all.
Just wanted to see if anyone else has seen this, our next step is to update the firmware but I did not want to do firmware updates during our busy season in case that causing any other issuers.
Ed
Solved! Go to Solution.
12-19-2011 12:23 PM
some new info...
Before the Firmware upgrade, after pressing Corporate Directory, we got a message saying to conatct Administrator.
After the upgrade, its just a blank screen that says unknown host.
I did the wireshark and I am looking at that now... I do not see where I can upload them.
12-19-2011 01:10 PM
Do a normal reply and just above the HTML tag in the top right is "Use advanced editor"
Click that and at the bottom is an Attach Files box
Graham
12-19-2011 01:11 PM
just a thought, but under the phone config in cucm admin, set the directories services to external.
12-19-2011 02:34 PM
12-20-2011 03:26 AM
The phone is not making any attempt to access CUCM for the directory XML.
Please try the following.
Login to Call Manager and select "Cisco Unified Serviceability"
Select Tools/Control Center - Feature Services, select the publisher IP address.
Under CM services restart the Cisco Tftp service. After it has restarted wait two minuets, reset one of your problem 7942 phones and see what happens.
If it still fails do a Fcatory Reset on the phone and try again.
If it still fails I want you to download the phone cnf file and post it to the forum.
On any PC open a cmd window, do a cd to a sutable directory, then enter
tftp 10.10.66.34 get SEPE80462127D04.cnf.xml.sgn
and post the resulting SEPE80462127D04.cnf.xml.sgn file
Graham
02-02-2012 08:14 AM
Wanted to provide an update... This is still not working but I believe I found what may be the issue, just not sure why. Perhaps a new bug. ... But hopefully this may save someone a lot of frustration
To narrow things down a bit, I created a test Device Pool, test Region, and test MRGL, Etc.. and moved a few test phones into it. I edited one thing at a time editing; the MRGL, Region, Date and Time made no difference still no corporate directory on the 7962s, but the 7940s and 7960s still worked.
When I disabled the SRST Reference in the test device pool, the corporate directory started working on the 7962s and it still works on the 7940s and 7960s. however when I re-enable it only the 7940s and 7960s corporate directory works… the 7962s does not and says “Host Not Found”. I am still digging through all the logs myself but this totally makes no since which is why I think it is a new bug.
I have summed this up for TAC with a TON of logs from the phone to back this up. Hopefully we will be able to move forward with this soon.
Any other thoughts let me know but I will post the resolution once I have it… hopefully this week.
Ed
02-10-2012 05:45 AM
RESOLVED!!!!
Finally we have this fixed, Apparently the 7962s use DNS for some of the backend functions where the 7940s and 7960s do not. Per TAC, this may still be a bug, as there was no clear explanation to why, we have about 1000 phones and have not needed to do this before the 7962s.
The Fix was simply adding DNS to the DHCP router so the phones would get the DNS setting.
Just glad it is fixed.
Thanks all.
06-17-2012 04:06 AM
Hi Ed,
Thanks for confirming the issue.
I saw your case within TAC DB.
Since the 7960 Phones are working with the DNS enabled, could you send us those sniffers(working)?
It will help me to raise a bug with the development team and help other customer's too. Really intresting to know why these model phones need DNS!
Looking forward for a reply.
Thanks.
Regrads,
DJ
