IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6134 Views
  • 14 replies
Hello! We have some problems with CUBE. We have Cisco 4321 router with IOS XE isr4300-universalk9.16.05.01b.SPA.bin. We received sip profiles from ITSP. But when i configuring this profiles in sip-ua with command credentials I received this error:%PA...
Resolved! CP-8831
Hi All,   I have two CP-8831. All two request encrypted configs (.sgn). I would like change the firmware on unit, because those not compatible the keypad V02. Possible switch off the encrypted config request? No have a CUCM, just a simple TFTP server...
I am trying to use GMAIL smtp.gmail.com for my CUE for message notification.  I have so far been unable to get it to work.     When I try to send a test email I get "unable to connect to smtp host".  However.  When trying this from CME, I am able to ...
Stuart C by Level 1
  • 2615 Views
  • 9 replies
i have a query releated to CDR, due to some issue server was unreachable but back in 2 mins,    now when i am seeing on router flash it shows 2 files remains there   my config is as below gw-accounting file primary ftp IP Address/BibCme1/ username an...
alap84 by Level 1
  • 490 Views
  • 5 replies
