cisco 8831 can not register
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-05-2019 10:07 AM - edited 03-17-2019 02:03 PM
I have new 8831, and i am using CME :Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.4(1)T1, RELEASE SOFTWARE (fc2)
the 8831 can get ip and goes to voice vlan. I can ping the phone ip by CME, but the phone just keep showing Phone not registered. Dose anyone know how to fix it
! voice service voip no ip address trusted authenticate no supplementary-service sip handle-replaces fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none sip registrar server ! voice register pool-type 8831 xml-config maxNumCalls 4 xml-config busyTrigger 4 xml-config custom sshAccess 0 description CISCO IP phone 8831 reference-pooltype 9971 ! voice register global mode cme source-address 192.168.100.2 port 5060 max-dn 4 max-pool 5 load 8831 sip8831.9-3-3-5 authenticate register authenticate realm cisco.com create profile sync 0253815872624616 conference hardware ! voice register dn 1 number 150 name Boardroom A ! voice register dn 2 number 151 name Boardroom B ! voice register template 1 ! voice register pool 1 busy-trigger-per-button 1 id mac XXXXX type 8831 number 1 dn 1 template 1 dtmf-relay rtp-nte sip-notify username 150 password cisco codec g711ulaw ! voice register pool 2 busy-trigger-per-button 1 id mac XXXXXX type 8831 number 1 dn 2 template 1 dtmf-relay sip-notify username 151 password cisco codec g711ulaw
The dn 1 is working fine, I am having issue with dn 2
- Labels:
IP Phone and Accessories
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2019 10:27 AM
So, you have one 8831 successfully registered but another is not registering?
Have you performed factory reset on the phone?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2019 11:31 AM
for the new one, i did .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2019 10:38 AM
It looks like there is some kind of issu with this phone so you should hardware reset it and try to register it again.
Upon connecting it back to network try to create-cnf files again on CME
George
gsotirop
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2019 11:35 AM
i am totally new to voip. would you mind get me some detail about create-cnf file?
I reset the phone already
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2019 11:53 AM
On your CME Router, enter
conf t
telephony-service
create cnf
george
gsotirop
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2019 12:12 PM
create cnf-files version-stamp 7960 Feb 05 2019 13:06:03
I created it, and still does not work, do you need my all config?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2019 10:46 AM
Does the phone also receive the TFTP server info from DHCP or is it maybe hard coded on the second phone?
Do you see REGISTER messages coming from the phone to your CME?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2019 10:57 AM
Pool Tag 2 Config: Mac address is AC44.F213.6D0B Type is 8831 Number list 1 : DN 2 Proxy Ip address is 0.0.0.0 DTMF Relay is enabled, sip-notify Call Waiting is enabled DnD is disabled Video is disabled Camera is disabled Busy trigger per button value is 1 keep-conference is enabled registration expires timer max is 3600 and min is 60 username 151 password cisco template is 1 kpml signal is enabled Lpcor Type is none Transport type is udp service-control mechanism is not supported Registration method: per line Privacy feature is not configured. Privacy button is disabled conference admin: no conference add mode: all conference drop mode: never Reason for unregistered state: No registration request since last reboot/unregister paging-dn: config 0 [multicast] effective 0 [multicast] Dialpeers created: Statistics: Active registrations : 0 Total SIP phones registered: 1 Total Registration Statistics Registration requests : 0 Registration success : 0 Registration failed : 0 unRegister requests : 0 unRegister success : 0 unRegister failed : 0 Attempts to register after last unregister : 0 Last register request time : Last unregister request time : Register success time : Unregister success time :
no request to cme
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2019 12:47 PM
What about the TFTP on the phone? You could try to enter it as alternate TFTP if you have problems with your DHCP. Also, is this a used phone? Maybe it has an ITL installed which does not trust your CME and blocks registration (delete ITL file then).
As you're using SIP phones for creating profiles you'd need to enter:
no create profile
create profile
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2019 01:35 PM
Hi there
Try removing the below commands and apply 'create profile' command on 'voice register global'
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-06-2019 07:16 AM
I reboot the CME and the phone register successfully
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-06-2019 07:15 AM
TFTP is working fine because I have another 8831 is running, I reboot the CME and the phone register successfully .
Thank you
