Are there any good guides on how to get this to work? I've got SSO working beautifully, but it does require the user to login to Jabber manually the first time they log into a particular PC. Subsequent logins are obviously perfect. I've forced th...
Hello Everyone, Good Day. Is there any document stating the maximum number of call blocking we can do on a H323 gateway (ISR 4321)? Also is the "Route Next Hop by calling Party Number" can be used as call blocking after reaching the call blocking l...
I am trying to register an 8841-3PCC phone with an Avaya IP Office and I need a $PSN.xml file. Where do you get this file from? Thanks -mike
Experts, We have CUCM V11. The call flow is simple one. Calls from customer to SIP VG then to CUCM extensions. We noticed that when a customer calls the DID, the caller hears the ringtone and when that user transfers the call to another extensio...
I am in the midst of home labbing, about 3 weeks in to studying for the CCNA collaboration exams. In following along with the CBT Nuggets series I have set up a POTS Dailpeer out an FXS port. I can answer and make calls from the analog phone, and rec...
Hi, I have a small business with only one Cisco 8841 phone. I don't care for the ring tones on the phone and would like to upload a different ringtone. I have looked through the 8841 configuration utility and cannot locate where I might upload a ring...
i try to do config call blast hunt-group parallel but cannot to inject command list . anyone help me it reture as "Number xx is not a valid voice register dn. Re-enter 'list.'" i have require all ip phone ring form PSTN Incomming call. my ip ph...
Good day Experts.. I seem to be running in to some complex configurations day in day out huh... Anyways I have a SIP trunk from MyPBX to CUCM that is working perfect thanks for the team here for bringing it up adn working. Issue is CUCM has SIP t...
Hello Guys, We have two CUCM clusters A and B. SIP trunk is configured between these 2 clusters. Geo Location policies are configured for both the clusters. User From Cluster A is trying to make conference as below. 1. He makes 1st call to Mobi...
Hi, I have installed a CUCM 9.1, with one Publisher and one suscriber. I configure some cisco 7821, and they are registered in the Publisher. The information in "Device Information" in the "Download Status" is "Sucessfull", but when I register this t...
Hi, We've got a weird problem that seems to only affect 7941 and 7970 phones. We've getting a lot of errors in the logs on the switches:Feb 20 14:17:34: %SWITCH_QOS_TB-5-TRUST_DEVICE_LOST: cisco-phone no longer detected on port Fa2/0/21, operational ...
I have CUCM self-signed (CAPF I believe) certs on my 7900 and 8800 series phones that are used to establish AnyConnect SSL VPN. If I have a problem with a remote phone I want to make sure that I don't delete this cert. What reset options can I use ...
Hi I have recently deployed 200 Cisco 8841 IP Phones to a new build, using Cisco 3850X switches with 1400W Power and making use of PowerStack. I am finding phones are randomly rebooting themselves. I have run some debugging and seen the following:Mar...
Dears, I have installed a new switch for IP phone the configuration I put to ports ( switchport voice vlan 1 ) but the phone still shows a message verify your network connection, and when I change the configuration to ( switchport access VLAN 1 ) the...
Subject | Author | Posted |
03-20-2025 05:12 AM | ||
03-20-2025 03:51 AM | ||
03-19-2025 06:53 AM | ||
03-18-2025 05:41 AM | ||
03-16-2025 03:42 AM |
User | Count |
6 | |
3 | |
3 | |
2 | |
1 |
