03-31-2015 12:54 PM - edited 03-17-2019 02:30 AM
Working with a customer to setup a Cisco ATA 190. Skimmed the administration doc but wanted to get confirmation on this. Can we use the ATA 190 without a Call Manager? We are attempting to connect this to another vendor's SIP proxy.
03-31-2015 07:20 PM
Hi Dan,
This should be checked with the third party with which the ATA is being integrated. Just like CUCM has the option of adding 3rd party SIP they might have a similar option.
Manish
03-31-2015 08:12 PM
Hi Manish,
I appreciate the response. The third party does have a SIP Proxy/Gateway to register the ATA to. Can we configure the ATA without a CCM? If so, where are those instructions. I haven't seen them. We need to assign it to an IP (not using DHCP).
Dan
03-31-2015 08:50 PM
It *might* be possible, notice Cisco does not test endpoints with any other call control agents, just as we do not have any documentation for trying to register it to them.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cata/190/1_0/english/administration/guide/sip/ATA190/a190_agBcd.html#20224
You may want to try resources like voip.org
