Allow Web Access to the ATA
To view the ATA parameters, enable the configuration profile. To make changes to any of the parameters, you must be able to change the configuration profile. Your system administrator might have disabled the option to make the ATA web user interface viewable or writable.
For more information, see the Cisco ATA 191 and 192 Multiplatform Firmware Provisioning Guide
Before you begin
Access the phone administration web page. See Access the Phone Web Interface.
Procedure
Step 1 |
Click . |
Step 2 |
In the System Configuration section, set Enable Web Server to Yes. |
Step 3 |
To update the configuration profile, click Submit All Changes after you modify the fields in the phone web user interface. The phone reboots and the changes are applied. |
Step 4 |
To clear all changes that you made during the current session (or after you last clicked Submit All Changes), click Undo All Changes. Values return to their previous settings. |
