Cisco Collaboration CUCM
Can we Use UCS C220M3S server for call manager 12.5 version  ?
if yes which firmware version should be running on UCS C220 M3S ?
Thanks for the so quick reply.
we have esxi 6.5 running and this would be fine to upgrade to version 12.5. No need to upgrade the ESXI , correct ?
And the firmware used by UCS C220 M3S need to be upgraded or that would work just fine,
The current firmware version running on UCS C220 M3S is Firmware Version
2.0(8d)
