cisco cp-7942g problem
wael azzam
hi all.
we bought new cisco cp-7942G ip phone .after installation and configure it to ccme ,it doesnt register to cme oe even get ip in the voice vlan .
And it just show (configuring ip) message on the screen
SO what is happen??
ronpatel
Level 8
Level 8
How is DHCP configured. Can you share the config of the router. Is DHCp enabled on Ip phone.
regards
Ronak Patel
Please rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
15 Replies 15
ronpatel
Level 8
Level 8
regards
Ronak Patel
dhcp is configured and the other phones can get ip
this is dhcp configuration
ip dhcp pool DHCPserver
   network 192.168.2.0 255.255.255.0
   option 150 ip 192.168.1.1 // loopback interface
   default-router 192.168.2.1
this is the new phone conf.
ephone-dn  86
number 2220
description wael
name wael
ephone  86
mac-address 2037.0616.E36B
type 7942
button  1:86
Wael,
Did you compare the Switch Port config of this phone ( in issue ) with other working phones ? Any difference ?
GP.
Pls rate helpful posts !!
abarkalg
Hi Wael,
             Check if the Port where the phone is plugged into has the voice lan confgured (switchport voice vlan ). Also try to see if you can give the IP manually on the phone and check if it registers. Make sure the DHCP is enabled in the CME to give the IP to the phone.
Do you have other phones which are registered to this CME?
Please rate helpful posts!!!
Abdul
i install another one 7912 in the same port its ok
how can i  give ip manually to the phone
for giving ip address manually
1) Do **#
2) Disable DHCP yes
3) Give ip address, Mast, Default gateway and Tftp ip address.
regards
Ronak Patel
Rate helpful posts
Do you see any CCM ip address already present in ip phones configuration. If yes do one thing
1) Press **#
2) Go to erase configurtion and select yes.
3) It will restart and it will start configuring phone again.
Tell us what happens after that.
Also send debug tftp outputs when this phones is regestering after the bove procedure.
Ronak patel
better than before but it get ip in the data vlan even though it see voice vlan not data
HI
Paste configuration from the switch port in which this phone is connected.
Ronak Patel
Rate helpful posts
bingo
its done
the switchs we have 300 series ,i found that i must enter part of mac of the phone using switch gui
Thanks every one for helping me
sorry but i did't get the solution. will you please explain a little bit what you did there.
