Bookmark
Subscribe
1267
Cisco Cube LineSide Configuration
Jason Ryan
I am walking through the guide for the Cube line side setup.
However, Im missing some of the commands from my router (Cisco 2921 with UC license installed).
For instance, I do not have the option of:
voice service voip
     extension cucm
or
voice-ctl-file
My global voice config is:
voice service voip
 mode border-element license capacity 25
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 sip
Show cube status:
CUBE-Version : 9.0
SW-Version : 15.2.4.M6a, Platform CISCO2921/K9
HA-Type : none
Licensed-Capacity : 25
What am I missing to activate this?
Jason Ryan
Aditya Gupta
Hi Jason
As per document below :
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube_interop/configuration/15-mt/cube-interop-15-mt-book/voi-cucm-lineside.html
Feature Name
Releases
Feature Information
Simplified Line-Side Support of CUCM on CUBE
15.4(2)T
Cisco IOS XE Release 3.12S
The Simplified Line-Side Support of CUCM on CUBE feature simplifies the complex CUBE configurations required for registering IP Phones on a CUCM through CUBE using a single CLI that automatically applies all the necessary configurations.
The following commands were modified by this feature: extension cucm and voice-class sip extension cucm.
Cisco Unified Communications Manager Line-Side Support
15.3(3)M
Cisco IOS XE Release 3.10S
The Cisco Unified Communications Manager Line-Side Support feature provides line-side support for Cisco Unified Communications Manager and IP phones deployed on different logical networks, in both cloud-based and premise-based deployments.
The following commands were introduced or modified: access-securecapf-addressclear voice phone-proxy all-sessionscomplete (ctl file)ctl-file (phone proxy)debug voice phone-proxydescription (ctl file)description (phone proxy)disable service-settingsmax-concurrent-sessionsphone-proxy (dial peer)port-rangerecord-entryshow voice class ctl-fileshow voice class phone-proxyservice-mapsession-timeouttftp-server address,voice-ctl-filevoice-phone-proxy.
Seems like you are running below the minimum version requirement for this feature.
Aditya Gupta
5 Replies 5
Aditya Gupta
Hi Jason
Feature Name
Releases
Feature Information
15.4(2)T
15.3(3)M
Aditya Gupta
Hi Aditya,
Very useful information (+5) for me too as I was looking for it.
Vivek
Hi Aditya,
I did see that at the bottom of the guide, though I read it as saying they simplified the setup in the that OS but not necessarily added it in that one.
Ill upgrade the OS and give it a shot.
Jason Ryan
Aditya,
I updated to 15.4 as mentioned and the commands were there.
Thanks for the help.
Jason Ryan
martyn.rees
Level 4
Level 4
If possible, I'd be interested in seeing your final config if you manage to get it working, along with what handsets you get working.
I haven't seen it working in any attempts made, and there doesn't seem to be much TAC knowledge to provide support on it either.
