Cisco CUCM
Shiraz Ali
Hi All,
We have installed VM for Cisco CUCM 12.x, i want to install it with HA - High availability.
Kindly confirm we require for Cisco CUCM VM
Jaime Valencia
SRND covers redundancy, CUCM install guide covers how to install subscribers and the UC virtualization site contains all the HW/SW requirements.
I'd strongly suggest you reach out to a reputable consultant or a local Cisco partner WITH voice specializations for assistance if you're not familiar with this.
java
if this helps, please rate
When you write “HA - High availability” what is it you refer to?
CUCM is per design build with HA - High availability in mind with the concept of publisher and subscribers.
If you’re referring to the VM infrastructure in it self it’s a different matter. For this you’d need to reference the design documents for ESXi by VMware.
Response Signature
George Sotiropoulos
In addition to what JaVa and Roger already replied, I would strongly suggest to Contact a Cisco Partner to discuss with you on your actual requirements/enviroment and provide to you Consultancy Services, accordingly.
You could use Cisco Partner Locator (under Technology choose "Collaboration")
https://locatr.cloudapps.cisco.com/WWChannels/LOCATR/openBasicSearch.do
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
