Cisco IAD2432 dial-peer In out ?
PseudoCyber
Hey all
In no way am I experienced in Cisco switch/router/IAD provisioning
But i have programmed a few PBX in my time
Having a tough time getting inward calls from My T1 pri to get to The Analog FXS port on a IAD2432
I'm pretty sure its a Dial-peer issue
If you could Take a look and tell me what I'm doing wrong?
outward calls work
There's only 4 analog
ANY help would be appreciated   ... (I have cookies!)
Dial-peer
SBWROUTER#show runn | b dial-peer
dial-peer voice 3 pots
preference 2
destination-pattern 8505
port 2/2
dial-peer voice 10 pots
destination-pattern .T
port 1/0:23
forward-digits all
dial-peer voice 1 pots
port 2/0
dial-peer voice 2 pots
port 2/1
dial-peer voice 12 pots
incoming called-number .
direct-inward-dial
port 1/0:23
dial-peer voice 4 pots
port 2/3
dial-peer hunt 7
Thanks in advance for any help
One Recommendation, try to avoid .T for outgoing dial-peers. Make it more precise.
port 1/0:23
forward-digits all
You have dial-peers pointing to FXS ports with 8XXX. What called informations does your ISP sends, is it a full digit or 4 digit? You might need to do translation. Is it a CME or CUCM deployment ?
can you share the output of debug isdn q931 and debug voice ccapi inout.
Response Signature
5 Replies 5
port 1/0:23
forward-digits all
Response Signature
Thanks for the reply Nithin,
Outbound calls - do I need <xNum> dial-peers? Not sure what else to use ... they (end-user) calls all over the world!
It a full XXX-xxx-XXXX 10 digits on the inward calls
I'm thinking it's a CME (not really hip to the cisco lingo)
it's a small company, not enterprise
TBH it looks like its looping on the debug ... just scrolls and scrolls
not that it helps but I think it's IOS 12.4 ...
Thanks for the Help (what kind of cookies do you like?)
(debug logs attached)
Nithin,
Thank You!
Yes the ".T" on the outbound calls was "looping" the T1 and generally causing issues
Had to fully "break-out" the dial-peers and translations
You're the best!
Here's a cupcake ... sorry ran out of cookies
___________________¶¶¶¶¶¶
_________________¶¶¶¶¶___¶¶
________________¶¶¶¶¶¶¶___¶
_______________¶¶¶¶¶¶¶¶¶¶¶¶¶
___________¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶
________¶¶¶¶¶___¶¶¶¶¶¶¶¶¶¶¶____¶¶¶¶¶
_____¶¶¶¶_________¶¶¶¶¶¶¶__________¶¶¶
____¶¶¶______¶____________________¶__¶¶¶
___¶¶________¶¶__¶¶_____¶¶__¶¶¶________¶¶
__¶¶_______________¶¶__¶¶_____¶¶¶_______¶¶
_¶¶______________________________________¶
¶¶________________________________________¶
_¶¶¶____________________________________¶¶
___¶¶¶¶¶____________________________¶¶¶¶¶
____¶¶_¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶_¶
_____¶____¶_____¶____¶¶____¶_____¶¶___¶¶
_____¶____¶¶____¶____¶¶____¶_____¶____¶
_____¶¶____¶____¶¶___¶¶___¶¶____¶¶___¶¶
______¶____¶¶___¶¶___¶¶___¶¶____¶____¶
______¶¶____¶___¶¶___¶¶___¶¶___¶¶___¶¶
_______¶____¶¶___¶___¶¶___¶____¶¶___¶
_______¶¶___¶¶___¶___¶¶___¶____¶___¶¶
________¶____¶¶__¶¶__¶¶__¶¶___¶¶___¶
________¶¶____¶___¶__¶¶__¶___¶¶__¶¶
_________¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶
Scott Leport
Level 7
Level 7
The call is looping between dial-peer 12 and dial-peer 10. So the dialled number isn't matching your destination-patterns attached to your FXS lines.
Might be better to see your config, but I suspect you'll need to modify or create some voice translation rule settings to translate the dialled number attached to your FXS lines.
Scott,
You're right, that's exactly what I had to do
I was hoping not to get that far into it, but I should know better
Have a coffee on me...
_________________¶¶¶1___¶¶¶____¶¶¶1_______________
__________________¶¶¶____¶¶¶____1¶¶1______________
___________________¶¶¶____¶¶¶____¶¶¶______________
__________________¶¶¶____1¶¶1___1¶¶1______________
________________1¶¶¶____¶¶¶____¶¶¶1_______________
______________1¶¶¶____¶¶¶1___¶¶¶1_________________
_____________¶¶¶1___1¶¶1___1¶¶1___________________
____________1¶¶1___1¶¶1___1¶¶1____________________
____________1¶¶1___1¶¶1___1¶¶¶____________________
_____________¶¶¶____¶¶¶1___¶¶¶1___________________
______________¶¶¶¶___1¶¶¶___1¶¶¶__________________
_______________1¶¶¶1___¶¶¶1___¶¶¶¶________________
_________________1¶¶1____¶¶¶____¶¶¶_______________
___________________¶¶1____¶¶1____¶¶1______________
__________________1¶¶1___1¶¶1____¶¶1______________
_________________¶¶¶____¶¶¶1___1¶¶1_______________
________________11_____111_____11_________________
__________¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶________
1¶¶¶¶¶¶¶¶¶¶¶__¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶________
1¶¶¶¶¶¶¶¶¶¶¶__1¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶________
1¶¶_______¶¶__1¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶________
1¶¶_______¶¶__¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶________
_¶¶¶¶¶¶¶¶¶¶¶__¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶________
__________¶¶___1¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶1________
__________1¶¶___¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶_________
____________¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶11__________
11_____________________________________________111
1¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶1
__¶¶111111111¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶¶111111111¶__
