Cisco IP Communicator: "Network" tab grayed out for standard PC Users
James Carlson
Hello. I am running Cisco IP Communicator v8.6.6 with Cisco CUCM v 9.1.2. I have allowed the Users group full permissions to the C:\Program Files (x86)\Cisco Systems directory on the PCs where the application is installed. However, when they login to the application and right-click and go to Preferences, the Network tab is grayed out. If I try to "Run as Administrator" it is grayed out, too.
I can login as my network admin account and I then have access to the options to change the Device Name and specify the TFTP servers. I know this looks like a permissions issue, but if I grant full access to the directory for the Local PC Users group, shouldn't that open the Network tab up to where we can modify it? Is there a setting I can change to open this up to the users?
Any recommendations is greatly appreciated.
Thanks!
7 Replies 7
Aseem Anand
Hi, Ideally yes if you have given the user full permission then it should not happen, however a couple of things which you can do:
1. Disable User access control
or
2. Login with Admin account and  change the compatibility mode of the CIPC to run in win xp compatibility mode.
3. Right click on the CIPC application >>> Properties >>>> Security >>>> Click on Add >>> You can add the specific account there or you can just add everyone there.
Aseem
(Please rate if useful)
Susan Arbogast
Network Tab grayed out in CIPC on Windows 10 machines - Fix is to update compatibility
Right Click Cisco IP Communicator
Select Troubleshoot Compatibility
Try recommended settings
Click Test the program (will show new compatibility settings
Set Network Adapter: Cisco AnyConnect Secure Mobility Client
TFTP Servers:  Enter your TFTP Servers
Click Next
Yes, save these settings for this program
Susan Arbogast
Click Test the program, shows new compatibility settings
Click Next
"Run as Administrator"    now right click on CIPC >exit.....now again "Run as Administrator"
Saiful Islam
Simple but effective solution
jcastillo30
The answer is simple- Run the app as administrator. Once you run the app as admin the gray out will disappear.
45-Fish-Nets
when you exit the program its still running at the background , go to TASK MANAGER kill the cisco IP communicator task.
go back to to the icon right clikc and run as admin , check you network tab you should be able to edit the IP Address  .
