10-02-2016 09:55 PM - edited 03-17-2019 08:14 AM
I have a Cisco IP phone 7942, user reported to me that her phone cannot keep the record for missed call/placed call/received call.
Have tried to factory default and change another phone for user but still have the same problem.
Our CUCM version is 10.5.1
and the user's phone is SCCP42.9-3-1SR3-1S
Thank you for your help
10-02-2016 11:16 PM
Hi Terry,
Can you compare the Device pool and switchport config of this 7942 with another working phone and make sure they are the same. If the issue started after any firmware upgrade or downgrade then try reverting to the same version and test.
Manish
10-02-2016 11:44 PM
Hi Manish,
I have checked that this 7942 phone is in the same device pool and config with others, also they are using same firmware version.
The strange is that the same user has problem even she change to another physical phone.
10-02-2016 11:50 PM
Since the issue is following user, I am assuming that he/she is using EM if this is the case then can you check if Log Missed Calls option box is checked or not on the DN level in Device Profile. if the user is not using EM, then can you try deleting and recreating the user and then check.
Deepak
10-02-2016 11:56 PM
I agree with Deepak, if the issue still persists I would recommend opening a TAC case.
Manish
10-02-2016 11:57 PM
Hi Deepak,
The Log Missed Calls option already selected in the Line Appearance in the phone config.
10-14-2022 01:59 AM
Log missed call disabled in Line page , That was the issue in my case
10-02-2016 11:57 PM
Please erase the ITL file on the phone
On the phone go to Settings > Security > Trust List > ITL File > **# (to
unlock the settings) > Erase. The phone will reset.
Then please restart the TFTP service on call manager. Let me know if it helps.
Aseem
