Cisco IP Phone CP-8941 Registerd
Murad*
i have new cisco ip phone cp-8941 , and when i connected it to the network , the phone detect the domain server and took dhcp ip but status staid not registered
so how i can config his extension ? and with witch method ?
i tried to upload SEP(mac).xml file and dialplan.xml file  and i think its upload normally but there is file didnot upload
you can check it on picture
and this is phone information ?
MAC Address 5CA48AFF45AS
Host Name SEP5ca48aff45AS
App Load ID SIP 9-3-4-17
Boot Load ID 0.0.1.0
Hardware Revision 3
Version V02
Serial Number PUC17460M3S
Model Number CP-8941
Message Waiting No
UDI Phone
  CP-8941
  PUC17460M3S
  V02
Time 21:17
Time Zone None
Date 08/01/13
George Sotiropoulos
Can you clarify if you use CUCM or CME?
G
Hope the above helps,
gsotirop
i not have CUCM , i use Elastix server as call manager
Check the security menu and verify that the ITL/CTL have been erased. Assuming this phone is used off greymarket and previously registered to Cisco call control it will reject XML files that aren’t digitally signed by that previous system.
