CUCM-11.5 IOWAIT and IPOS Requirements
aniket0422
Can someone please help me with below details.
Application Short Name Application Long Name Release VM Name Min IOPS/instance Typical IOPS Max IOPS IOPS Block Size CPU Util Min Treshold IO Wait Min Treshold Network Bandwidth Requirements
CUCM Unified Communications Manager Release 11.0 CallCtrl: 150 users
CUC Unity Connection Release 11.0 1,000 users
CUCCX Cisco Unified Contact Center Express / Unified IP IVR Release 11.x Main: 100 agents
QM Recording Cisco Unified Contact Center Express / Unified IP IVR Release 11.0 QM Recording Server 4vCPU
amanchau
Hi Aniket,
As per my understanding and according to the snap you want to check for the IOPS for the specific version.
As rightly mentioned by Jonathan, IOPS will vary depending upon the activity in your cluster like : sending data to billing servers, collecting logs, backups.
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-unified-communications-manager.html#iops
Also IOwait indicates high disk I/O activities, The number of CPUs you have affects your percentage
I have seen high Iowaits causing issues, High Iowait can be due to several reasons : Hardware, db etc.
Anything over and above 25-30 % should be a concern.
You can use the perfmon tool to isolate and troubleshoot further.
Thanks & Regards
Aman Chaudhary
Please rate if found helpful
Jonathan Schulenberg
This is, to some extent, implementation/load-dependent. The only data I am aware of Cisco publishing on this front is here:
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/cisco-collaboration-virtualization.html
For example, clicking on CUCM shows some IOPS related data at the bottom of the page:
amanchau
Hi Aniket,
Thanks & Regards
Aman Chaudhary
