05-02-2023 09:16 PM
Hi all,
Is there a Cisco IP Phone that currently supports SIP and IPv6 at the same time?
05-02-2023 11:14 PM
Check the datasheets ...
05-03-2023 11:41 AM
Thanks, but if I could figure out with datasheets, I did not come here and ask.
05-03-2023 11:52 AM
All of Cisco’s current generation IP Phones exclusively run SIP. And to @b.winter ’s point, the data sheet does list IPv6 (I actually went to look myself). So, what are you asking then?
05-03-2023 11:55 AM
Links please?
05-03-2023 12:15 PM
The forum is not here do to the google search for you ... If others can find datasheets in the internet, I believe in you that you can do it too.
One hint: try to search for "cisco 78xx datasheet" or "cisco 88xx datasheet"
05-03-2023 02:05 PM
I don't ask you Google for me, I ask any expertise to help me if they actually have hands-on experience on these concrete experiment, can you don't be here and try to be "expertise"
05-03-2023 09:50 PM - edited 05-04-2023 04:17 AM
In your original post you wrote this.
”Is there a Cisco IP Phone that currently supports SIP and IPv6 at the same time?”
IMHO this is not asking for real world experience on the matter, it merely asks for if there are Cisco SIP phones that can do IPv6. On this matter you have got three people in the community giving you the answer.
To be frank you should have been able to get the information you’re asking for by doing some basic reading of available public information, it’s not like it’s hidden from sight, the information is there in plain sight.
05-04-2023 07:23 AM
Well, that's your own opinion, you think it that way. I will rate your answer as helpful when I see it. Thanks for your reply.
05-03-2023 11:54 AM
I searched for “cisco ip phone ipv6” and the very first result was this.
IPv6 Deployment Guide for Cisco Collaboration Systems Release 12.x and 14
05-03-2023 12:06 PM
Not just with cisco ip phone ipv6 but cisco ip phone with SIP-enabled
05-03-2023 12:10 PM - edited 05-04-2023 04:19 AM
All the models in the list in the document are from what I can tell SIP phones.
