Cisco IP phone wallpaper changing
nilotpald2
Wallpaper or IP phone background change in bulk using Common Phone profile in CUCM is possible only for 88xx series phones. However in 79xx and CIPC; user have to select the background from IP phone's settings menu. But we want to push the wallpaper from CUCM using common phone profile. Does anyone know have any solution for 79xx series and CIPC phones?
CUCM version 11.5.x
2 Accepted Solutions
You can set it as default wallpaper and it will populate automatically
without user intervention. Just save your image with the name
'CiscoPhoneLogo.png' and assign this name to the common phone profile >
background. Finally, use bulk to assign this profile your phones.
**** please remember to rate useful posts
I haven't tried it on CIPC but I know it's working on 7945/65. Give a try
for one of them as see if it works.
13 Replies 13
Thanks for replying.
I would like to know what is the default path for the image file "CiscoPhoneLogo.png" in CUCM nodes. Because for different phone models, there are different paths
Example for CP-7945 path is Desktops/320x216x16, for CP-8865 is Desktops/800x480x24.
Thanks, I will test and let you know.
Hi, I have uploaded the image "CiscoPhoneLogo.png" in "Desktops/320x212x12" for CIPC and put the image name in common phone profile. assigned the common phone profile to one CIPC phone, but no luck. Still user have to select the image from settings, it is not getting reflecting automatically in CIPC background.
For 7945 it is working. Really appreciate your support on this.
No worries. Good to know that you got it working. I tried on CIPC and its
not working. I don't think CIPC gets the same TFTP parameters are desk
phones.
Thanks, I am aware about this bug, looking for alternate solution.
Nithin, please refrain from posting images of the actual bug information and simply direct people to the bug via the URL, that information requires people to login in order to see it and you posting it like that bypasses such authentication mechanism.
java
if this helps, please rate
Noted and Removed the image.
Response Signature
Dear sir,
could you please share screenshot of the process or a video because i tried in our cisco 7945 ip phone but its not working
