04-27-2013 05:42 AM - edited 03-16-2019 05:02 PM
I have a strange problem . I have 30 Cisco IP phones when i attached them to a Cisco switch , the IP phones can not able to register. When i replace these Cisco IP phones on other switch , it work fine and register successfully. The configuration are same on both switches .
Switch 3750
Interface range f0/0 -8
switchport mode access
switch access vlan 10
switch voice vlan 20
spanning-tree portfast
I have already did many search with bad results , other thing the switch is POE if anyone asked about the type.
I apperciate your help
Solved! Go to Solution.
04-27-2013 07:09 AM
hi
can you check if some thing which stops your dhcp request?. I hope to check something like IP dhcp snooping. Check with your security team and please check your configuration. i hope to add the below commands to the interface which is connected to your router
interface
ip arp inspection trust
ip dhcp snooping trust
Thank you
please rate if this will help
04-29-2013 07:07 AM
hi
DHCP snooping is a security feature to prevent traffic to reach "man in middle" , you will get more information
http://www.youtube.com/watch?v=-Uzc3Vu_SRc
Thank you
04-27-2013 05:50 AM
Can the phones contact your DHCP server from this switch? If you plug a pc to one of the ports on the switch, do you get an IP?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
04-27-2013 05:57 AM
Hi Kamel,
Just to add what Mr. Aok has asked,what is the model and version of both the switches ?
How the switches are connected in setup?
regds,
aman
04-27-2013 06:56 AM
answer is no , my cisco IP phones can not contact my dhcp. I think i have a problem to get my IP address.
04-27-2013 07:02 AM
Hi Kamel,
Have u configured DHCP pool on switch?
Do u have enough IP addresses in pool to be allocated to IP phones?
regds,
aman
04-27-2013 07:09 AM
hi
interface
Thank you
04-27-2013 07:13 AM
Hello
Please clarrify also the dhcp configured on your CUCM , external server or router.
Thank you
04-27-2013 07:22 AM
thanks amanso and kamal , my dhcp server is on my CUCM and all things work fine . I think my problem in my switch , let me Mr/kamal check with security team if security commands are added to my config .
thanks
04-27-2013 07:24 AM
Hi Kamel,
Check for ACL.along with DHCP port 67 being opened.
regds,
aman
04-29-2013 06:48 AM
Kamal ,you are true .Our security team found that issue was dhcp snooping . I will apperciate if you give more details about this.
thanks again
04-29-2013 07:07 AM
hi
Thank you
