Cisco Jabber and SCCP Deskphone
shiblyibrahim
Level 3
Level 3
Hey Guys,
Need help here. I have got the same extension on botht he cisco jabber and sccp extension. But I cant get both these to ring at the same time.
Any suggestions....
Oh yeah I am using CME
Please rate the post Shibly Ibrahim
2 Accepted Solutions
Jaime Valencia
Support for Cisco Jabber
Cisco Unified CME 8.6 and later versions support Cisco Jabber. The  softphone SIP client is an iPhone application and works as a SIP  softphone. The SIP softphone client is capable of supporting VoIP over  WLAN. Cisco Unified CME 8.6 supports supplementary services such as  Hold, Resume, Transfer, Call Park, and Call Pickup for the softphone SIP  client.
Note
Shared line, conference, and hand-off call to GSM  are not supported.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
paolo bevilacqua
That is supported in CME 9.0
That means you will need and ISR G2 to use the features. It will never work on an ISR G1 router.
Jaime Valencia
Note
java
java
paolo bevilacqua
