Cisco Jabber for Android phones not working
@Syed
Level 3
Level 3
Hi Gents,
Jabber is not working on android phone, but the same works on laptop.
I have CSF for laptop and BOT for android, on login it throws an error : cannot find the server.
What could be the reason?
6 Replies 6
Jaime Valencia
Can the android device reach the servers via the hostname/fqdn?
Have you reviewed a PRT?
java
if this helps, please rate
User enters IP address of IM&P manually  in Jabber advance settings and it is a reachable.
Do I also need to verify IM&P is reachable by FQDN?
since this for a customer I shall review PRT on my next visit.
What do you use under system -> server? FQDN? hostname? IP?
java
IP address
The review the PRT to find out what's happening with the communication between Jabber and the servers.
java
Are the Android phones connecting to a guest wireless that doesn't have access to the server subnets?
Please remember to rate useful posts, click on the stars below.
