Hello Folks,I have a quite confusion over here. We are running CUCM 8.5. We want know the exact procedure to enable SSH login on cisco ip phone.Your answer is much appreciated.Kulasekara Raja. K
Fire voice call to monitor your critical number from Cisco voice getaway Cisco IP SLA VoIP Call Setup Monitoring story In the process of building a lightweight SIP call monitoring solution, I initially tested tools like SIPp and Python-based scripts...
Has anyone ran into the precop check for Source release only has swap space of 2 GB, which is not enough for destination release 15. We are running running 110 Disk CM 12.5 and our precheck is getting this. Should we try to upgrade and see what hap...
Hello there!In our CUCM setup (v15), the design choice for security reasons was to disable setting access via an IP Phone. So every setting needs to be pre-configured by the administrators (my team) via the enterprise phone configuration and common p...
Hello. I've spent a day or three trying to understand the NS OCI schema files and online Cisco OCI-P documentation. I'm able to get an NS system user logged in using OCI-P via the XSP server to the Network Server, but I am not able to form an accepta...
Hello All,We had a power outage and when power was restored this particular cisco phone didn't come up. I shut no shut interface it was connected to nothing. I then plugged the phone into different stack to test and it came up. Went back to previo...
Hello everyone,We have a SIP trunk between CUCM 11.5 and 3CX 20When making calls from 3CX to Cisco, Name and Number is visible on Cisco phone. But when making calls from Cisco to 3CX, only number is presented.I am looking at the logs on 3CX side, see...
Hello, I have a question regarding the box2box Cube HA. Our customer has a B2b configuration where each cube is connected to one switch on each end and there is direct connection between the cubes via Gigabit Port. The customer has tried to do a ...
I'm trying to connect my phone to my computer and give it a firmware update but whenever I put in its IP address into my browser it just gives me an error page saying "This site can't be reached". I no longer have a warranty for the phone but I did i...
Hello,We have a series of numbers in our Call Manager, where if they attempt for have their incoming calls forwarded to their cell, the caller gets a message from Verizon saying their call could not be completed.The common denominator with these numb...
please i wnat to know what type of Cisco Flex Licensing need of each type of ip phones 9800 series
I have a user configured with Jabber.When I search for the user, I don't have the option to call the user.The extension is assigned to the user...What is missing in the config that would cause this, or is there something else going on I'm not aware o...
I have had my first occasion to need RTMT v15 and was a little surprised to see it's not an installer anymore but rather a folder with a run.bat file to launch the app. I have previous versions of RTMT working fine on my Windows 11 box thanks to the ...
We are deploying Cisco 840s, have the smart launcher locked down to a single app the phone its self. However we would like the users to be able to connect their bluetooth headset without needing admin help. Is it possible to enable just the phone app...
Hello, I am working in an SSO configuration on CUCM & CUPS with a certificate signed through Azure. The certificate is valid until the end of the month. What is the process for renewing the certificate to ensure uninterrupted service?
| Subject | Author | Posted |
| 01-16-2026 05:58 AM | ||
| 01-16-2026 03:24 AM | ||
| 12-31-2025 01:52 PM | ||
| 12-10-2025 11:24 AM | ||
| 11-16-2025 10:18 PM |
