Cisco SIP trunk, Outbound Call errors
savio.ibrahim
Dear all,
I've established a sip trunk with ZTE MGW applianc but I'm receiving error everytime I use csim start for outbound calls,
The errors are the following ( debug ccsip errors):
Mar 26 17:41:47.467: //162/445401C08072/SIP/Error/sipSPIOutgoingCallSDP: Could not create source SDP for Outgoing Call
Mar 26 17:41:47.467: //162/445401C08072/SIP/Error/sipSPICreateOutboundSDP: Error in creating an SDP for the outbound call - Check for supported codecs
Mar 26 17:41:47.467: //162/445401C08072/SIP/Error/preprocessSetup: Error during outbound SDP creation
Mar 26 17:41:47.467: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG: No Inbound Container Created !!!
Mar 26 17:41:47.467: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931: No Inbound Container Created !!!
Mar 26 17:41:47.467: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_spi_process_ccapi_event: CCAPI Event Preprocessor Failure
Mar 26 17:41:47.467: voip_rtp_get_gccb:Error, no gccb for callID:162
Mar 26 17:40:02.955: //-1/xxxxxxxxxxxx/SIP/Error/get_content_length: Could not get Content-length
Mar 26 17:40:02.955: //160/000000000000/SIP/Error/ccsip_api_register_result_ind: Message Code Class 4xx Method Code 100 received for REGISTER
Mar 26 17:40:02.955: //160/000000000000/SIP/Error/sipSPIRegPthruProcessResponse: Error NO RPCB
Below the configuration and sip trunk status , kindly advise
show sip-ua connections udp detail
Total active connections      : 2
No. of send failures          : 0
No. of remote closures        : 0
No. of conn. failures         : 0
No. of inactive conn. ageouts : 1
---------Printing Detailed Connection Report---------
Note:
** Tuples with no matching socket entry
    - Do 'clear sip <tcp[tls]/udp> conn t ipv4:<addr>:<port>'
      to overcome this error condition
++ Tuples with mismatched address/port entry
    - Do 'clear sip <tcp[tls]/udp> conn t ipv4:<addr>:<port> id <connid>'
Remote-Agent:10.1.153.144, Connections-Count:1
  Remote-Port Conn-Id Conn-State  WriteQ-Size Local-Address
         5060       4 Established           0 10.1.149.61
Remote-Agent:10.1.138.32, Connections-Count:1
         5060       3 Established           0 10.1.149.61
-------------- SIP Transport Layer Listen Sockets ---------------
  Conn-Id               Local-Address
   2            [10.1.149.61]:5060
* Configuration:
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  session refresh
  header-passing
  registrar server expires max 3600 min 3600
  transport switch udp tcp
  asserted-id pai
  redirect contact order best-match
  early-offer forced
  midcall-signaling passthru
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g711alaw
codec preference 4 g729br8
dial-peer voice 3 voip
destination-pattern .T
b2bua
session protocol sipv2
session target ipv4:10.1.138.32
voice-class sip dtmf-relay force rtp-nte
voice-class sip bind control source-interface GigabitEthernet0/0
voice-class sip bind media source-interface GigabitEthernet0/0
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
credentials username orange password 7 11060B0419150E realm orange.cd
retry invite 2
retry register 10
timers connect 100
registrar 1 ipv4:10.1.138.32 expires 60
registrar 2 ipv4:10.1.153.144 expires 60
sip-server ipv4:10.1.153.144
host-registrar
15 Replies 15
daniel.bloom
Can you generate another call with the following debugs and post the result.
debug ccsip messages
debug voip ccapi inout
Dear Daniel,
This is the requested debug logs :
Mar 26 20:27:16.420: csim: called number = 0819890007, loop count = 1 ping count = 0
Mar 26 20:27:16.420: csimSetupPeer peer type(2), destPat(0819890007), matched(0), target()
Mar 26 20:27:16.420: //-1/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=FALSE, Mode=0,
   Outgoing Dial-peer=3, Params=0x30CF4F00, Progress Indication=NULL(0)
Mar 26 20:27:16.420: //-1/xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Mar 2
DRCCCVG02#6 20:27:16.420: //-1/xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=.T, Called Number=0819890007, Digit Strip=FALSE
   Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=0819890007(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=FALSE,
   Guid=627221E6-958A-11E2-8062-84E046538A50, Outgoing Dial-peer=3
Mar 26 20:27:16.420: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=0819890007
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Mar 26 20:27:16.420: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x2B663EB4, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=0819890007(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=3, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Mar 26 20:27:16.420: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 26 20:27:16.420: :cc_get_feature_vsa malloc success
Mar 26 20:27:16.420:  cc_get_feature_vsa count is 1
Mar 26 20:27:16.420: :FEATURE_VSA attributes are: feature_name:0,feature_time:814494248,feature_id:3
Mar 26 20:27:16.420: //93/627221E68062/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Mar 26 20:27:16.420: //93/627221E68062/CCAPI/ccCallSetContext:
   Context=0x3007B734
Mar 26 20:27:16.420: //93/627221E68062/SIP/Error/sipSPIOutgoingCallSDP: Could not create source SDP for Outgoing Call
Mar 26 20:27:16.420: //93/627221E68062/SIP/Error/sipSPICreateOutboundSDP: Error in creating an SDP for the outbound call - Check for supported codecs
Mar 26 20:27:16.420: //93/627221E68062/SIP/Error/preprocessSetup: Error during outbound SDP creation
Mar 26 20:27:16.420: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG: No Inbound Container Created !!!
Mar 26 20:27:16.420: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931: No Inbound Container Created !!!
Mar 26 20:27:16.420: //93/627221E68062/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x2B663EB4, Call Id=93
Mar 26 20:27:16.424: //93/627221E68062/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
Mar 26 20:27:16.424: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_spi_process_ccapi_event: CCAPI Event Preprocessor Failure
Mar 26 20:27:16.424: csim_do_test: cid(93), ev(12), disp(0)
Mar 26 20:27:16.424: csimTraceSct: cid(93),st(0),oldst(0)
Mar 26 20:27:16.424: csim err csimDisconnected recvd DISC cid(93)
Mar 26 20:27:16.424: //93/627221E68062/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
Mar 26 20:27:16.424: //93/627221E68062/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x2B663EB4, Tag=0x0, Call Id=93,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Mar 26 20:27:16.424: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 26 20:27:16.424: :cc_free_feature_vsa freeing 308C3220
Mar 26 20:27:16.424:  vsacount in free is 0
Mar 26 20:27:16.424: csim_do_test: cid(93), ev(13), disp(-11)
Mar 26 20:27:16.424: csimTraceSct: cid(93),st(2),oldst(0)
Mar 26 20:27:16.924: csim: loop = 1, failed = 1
Mar 26 20:27:16.924: csim: call attempted = 1, setup failed = 1, tone failed = 0
Mar 26 20:27:16.924: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   ccAppShutdownMode: remove it from the queue
Mar 26 20:27:21.580: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:Trunk_CiscoGateway01@10.1.153.130:5060 SIP/2.0
From: ;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-416
To:
Call-ID: 00274926-BE0F-1151-8B6C-8F99010AAA77-299@10.1.153.144
CSeq: 1364329725 OPTIONS
Content-Length: 0
Via: SIP/2.0/UDP 10.1.153.144:5060;branch=z9hG4bK0005B270-04FD-1152-8B6C-8F99010AAA77
Max-Forwards: 0
Mar 26 20:27:21.580: //94/65857C388065/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: ;tag=1AE85340-1FD4
Date: Tue, 26 Mar 2013 20:27:21 GMT
Server: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Accept: application/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 450
v=0
o=CiscoSystemsSIP-GW-UserAgent 3464 5525 IN IP4 10.1.153.130
s=SIP Call
c=IN IP4 10.1.153.130
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxFillBitRemoval:0
a=T38FaxTranscodingMMR:0
a=T38FaxTranscodingJBIG:0
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
DRCCCVG02#
Mar 26 20:28:21.660: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
From: ;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-417
To:
Call-ID: 00274926-BE0F-1151-8B6C-8F99010AAA77-300@10.1.153.144
CSeq: 1364329785 OPTIONS
Content-Length: 0
Via: SIP/2.0/UDP 10.1.153.144:5060;branch=z9hG4bK0011A206-0539-1152-8B6C-8F99010AAA77
Max-Forwards: 0
Mar 26 20:28:21.660: //95/8954F6888066/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: ;tag=1AE93DF0-2B1
Date: Tue, 26 Mar 2013 20:28:21 GMT
Content-Length: 450
v=0
o=CiscoSystemsSIP-GW-UserAgent 3928 3429 IN IP4 10.1.153.130
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
daniel.bloom
This seems robe failing before even generating a sip invite message. Can you generate a call using a phone rather than the csim command?
I don't think csim is supported with SIP trunking, as Daniel suggest please try making the call from a phone and provide the requested logs along with "sh run" of your router.
HTH,
Chris
Dear Danie,
The disconnect cause is 47 which is related to no ressources available . The voice gateway has two voice cards with PVDMv3, but due to interconnection issue, we're trying to get sip trunk
From sip phone, we're getting the same error. I should mention that we're using genesys IPT solution as part of the call center.
I've tried all supported codecs but resulting the same error
What do you think could be the issue, is it related directly to sip trunk
Do you think , it will be a better idea to connect directly the sip server (genesys) to ZTE MGW sip trunk without passing by cisco voice gateway, especially that the same link was used before to directly connect a sip server .
Can you send the debug ccsip messages and debug voip ccapi inout when you do a test with a phone. Also send your sh run as chris suggested.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Dear all,
this is the logs generated from sip phone , I'm getting a fast busy signal
Mar 26 22:12:59.435: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
Mar 26 22:12:59.515: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:900243819890007@10.1.153.130:5060 SIP/2.0
From: sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-597
To: <900243819890007>
Call-ID: 00274926-BE0F-1151-8B6C-8F99010AAA77-435@10.1.153.144
CSeq: 1 INVITE
Content-Length: 290
Via: SIP/2.0/UDP 10.1.153.144:5060;branch=z9hG4bK00274958-BE0F-1151-8B6C-8F99010AAA77-191
Contact: <5004>
Allow: ACK, BYE, CANCEL, INFO, INVITE, MESSAGE, NOTIFY, OPTIONS, PRACK, REFER, UPDATE
User-Agent: X-Lite release 1011s stamp 41150
Max-Forwards: 69
X-Genesys-CallUUID: 016E6N5U1S8L32RCHUCG22LAES000015
X-ISCC-CofId: location=KINSHASA;cofid=1060
Session-Expires: 1800;refresher=uac
Min-SE: 90
Supported: uui,100rel,timer
v=0
o=- 1364312166 1 IN IP4 172.16.30.25
s=CounterPath X-Lite 3.0
c=IN IP4 172.16.30.25
t=0 0
m=audio 7944 RTP/AVP 8 101
a=sendrecv
a=alt:1 2 : qDe/fv3+ xnhtY1La 192.168.42.21 7944
a=alt:2 1 : ekOn2k8A lIwI1VsI 172.16.30.25 7944
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
SIP: (43) Attribute mid, level 1 instance 1 not found.
Mar 26 22:12:59.519: //43/273998D48037/SIP/Error/sipSPI_ipip_update_codec_params_in_channelInfo:
failed to update call entry
Mar 26 22:12:59.519: //43/273998D48037/SIP/Error/sipSPI_ipip_update_call_entry:
Mar 26 22:12:59.519: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_set_channel_count: Unable to set CHANNEL_COUNT for callid 43
Mar 26 22:12:59.519: //43/273998D48037/SIP/Error/sip_iwf_sip_copy_sdp_to_channelInfo: Channel count is not set at this point. Not SIP-SIP or SET_MODE is not done.
Mar 26 22:12:59.519: //-1/273998D48037/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=5004
   cisco-ani=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-597
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=sip:900243819890007@10.1.153.130:5060
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Mar 26 22:12:59.519: //-1/273998D48037/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2B5FF334, Call Info(
   Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-597,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=sip:900243819890007@10.1.153.130:5060(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=3, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=43
Mar 26 22:12:59.519: //-1/273998D48037/CCAPI/ccCheckClipClir:
   In: Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-597(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-597(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Mar 26 22:12:59.519: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 26 22:12:59.519: :cc_get_feature_vsa malloc success
Mar 26 22:12:59.519:  cc_get_feature_vsa count is 1
Mar 26 22:12:59.519: :FEATURE_VSA attributes are: feature_name:0,feature_time:711117464,feature_id:6
Mar 26 22:12:59.519: //43/273998D48037/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Mar 26 22:12:59.519: //43/273998D48037/CCAPI/cc_process_call_setup_ind:
   Event=0x3204D278
Mar 26 22:12:59.519: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 900243819890007
Mar 26 22:12:59.523: //43/273998D48037/CCAPI/ccCallSetContext:
   Context=0x32A4E4D0
Mar 26 22:12:59.523: //43/273998D48037/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 43 with tag 3 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Mar 26 22:12:59.523: //43/273998D48037/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 26 Mar 2013 22:12:59 GMT
CSeq: 1 INVITE
Content-Length: 0
Mar 26 22:12:59.523: //43/273998D48037/CCAPI/ccCallDisconnect:
   Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
Sent:
SIP/2.0 403 Forbidden
To: <900243819890007>;tag=36C83C-84C
CSeq: 1 INVITE
Reason: Q.850;cause=21
Content-Length: 0
Mar 26 22:12:59.523: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:900243819890007@10.1.153.130:5060 SIP/2.0
CSeq: 1 ACK
Max-Forwards: 69
Content-Length: 0
Mar 26 22:12:59.527: //43/273998D48037/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2B5FF334, Tag=0x0, Call Id=43,
   Call Entry(Disconnect Cause=21, Voice Class Cause Code=0, Retry Count=0)
Mar 26 22:12:59.527: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 26 22:12:59.527: :cc_free_feature_vsa freeing 2A62CA90
Mar 26 22:12:59.527:  vsacount in free is 0
Mar 26 22:13:02.959: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
From: ;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-599
To:
Call-ID: 00274926-BE0F-1151-8B6C-8F99010AAA77-437@10.1.153.144
CSeq: 1364336077 OPTIONS
Content-Length: 0
Via: SIP/2.0/UDP 10.1.153.144:5060;branch=z9hG4bK006467B6-1DCD-1152-8B6C-8F99010AAA77
Max-Forwards: 0
Mar 26 22:13:02.959: //44/29471B30803C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: ;tag=36D5A8-12CA
Date: Tue, 26 Mar 2013 22:13:02 GMT
Content-Length: 450
v=0
o=CiscoSystemsSIP-GW-UserAgent 2403 2989 IN IP4 10.1.153.130
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Savio,
The reason is because CUBE is rejecting the call with cause code 21. This implies that the ip address sending the INVITE is not in the ip address trust list of CUBE
To resolve this add the iP address of the originating device to the CUBE trusted list as shown below
voice service voip
ip address trusted list
ipv4 10.1.153.144 255.255.255.255
Dear aok,
I'm using cisco 2921 as VG, don't have a CUBE device
I've adjusted the config as per recommendation but I'm still getting the busy signal with disconnect cause 102
I'm having a genesys sip server, which need to connect to cisco VG via sip trunk
Cisco VG is connected to another SIP trunk to reach MGW for PSTN
Kindly advise, I'm doing live test now
   cisco-username=5004
   cisco-ani=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-737
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=sip:90819890007@10.1.153.130:5060
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Mar 26 22:57:03.911: //-1/4F67CF3C806A/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2B62F434, Call Info(
   Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-737,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=sip:90819890007@10.1.153.130:5060(TON=Unknown, NPI=Unknown),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=57
Mar 26 22:57:03.911: //-1/4F67CF3C806A/CCAPI/ccCheckClipClir:
   In: Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-737(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-737(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Mar 26 22:57:03.911: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 26 22:57:03.911: :cc_get_feature_vsa malloc success
Mar 26 22:57:03.911:  cc_get_feature_vsa count is 1
Mar 26 22:57:03.911: :FEATURE_VSA attributes are: feature_name:0,feature_time:843467192,feature_id:26
Mar 26 22:57:03.911: //57/4F67CF3C806A/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Mar 26 22:57:03.911: //57/4F67CF3C806A/CCAPI/cc_process_call_setup_ind:
   Event=0x2BB3B7B8
Mar 26 22:57:03.911: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 90819890007
Mar 26 22:57:03.911: //57/4F67CF3C806A/CCAPI/ccCallSetContext:
   Context=0x2A64F4C0
   >>>>CCAPI handed cid 57 with tag 3 to app "_ManagedAppProcess_Default"
Mar 26 22:57:03.911: //57/4F67CF3C806A/CCAPI/ccCallProceeding:
Mar 26 22:57:03.911: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
   mempool not found from usrContainer(321A6220)
Mar 26 22:57:03.911: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
   Mempool(31B01B5C) created in usrContainer(321A6220)
Mar 26 22:57:03.915: //57/4F67CF3C806A/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=3, Params=0x2A64E050, Progress Indication=NULL(0)
Mar 26 22:57:03.915: //57/4F67CF3C806A/CCAPI/ccCheckClipClir:
   Destination Pattern=.T, Called Number=90819890007, Digit Strip=FALSE
   Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-737(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=90819890007(TON=Unknown, NPI=Unknown),
   Account Number=5004, Final Destination Flag=TRUE,
   Guid=4F67CF3C-959F-11E2-806A-DF2B2D79B65A, Outgoing Dial-peer=3
Mar 26 22:57:03.915: //57/4F67CF3C806A/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=5004
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=90819890007
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Mar 26 22:57:03.915: //57/4F67CF3C806A/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x2B62F434, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-737,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=90819890007(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3, Call Count On=FALSE,
Mar 26 22:57:03.915: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 26 22:57:03.915: :cc_get_feature_vsa malloc success
Mar 26 22:57:03.915:  cc_get_feature_vsa count is 2
Mar 26 22:57:03.915: :FEATURE_VSA attributes are: feature_name:0,feature_time:843466744,feature_id:27
Mar 26 22:57:03.915: //58/4F67CF3C806A/CCAPI/ccIFCallSetupRequestPrivate:
Mar 26 22:57:03.915: //58/4F67CF3C806A/CCAPI/ccCallSetContext:
   Context=0x2A64E000
Mar 26 22:57:03.915: //57/4F67CF3C806A/CCAPI/ccSaveDialpeerTag:
Mar 26 22:57:03.915: //58/4F67CF3C806A/CCAPI/cc_api_call_proceeding:
   Interface=0x2B62F434, Progress Indication=NULL(0)
Mar 26 22:57:07.415: //58/4F67CF3C806A/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x2B62F434, Call Id=58
   Call Entry(Responsed=TRUE, Cause Value=102, Retry Count=0)
Mar 26 22:57:07.415: //57/4F67CF3C806A/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Mar 26 22:57:07.415: //58/4F67CF3C806A/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=58
Mar 26 22:57:07.415: //58/4F67CF3C806A/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=102)
   Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102)
Mar 26 22:57:07.415: //58/4F67CF3C806A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2B62F434, Tag=0x0, Call Id=58,
   Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0)
Mar 26 22:57:07.415: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 26 22:57:07.415: :cc_free_feature_vsa freeing 324647F0
Mar 26 22:57:07.415:  vsacount in free is 1
Mar 26 22:57:07.415: //57/4F67CF3C806A/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Mar 26 22:57:07.415: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
   data = 2C28BEB8
Mar 26 22:57:07.415: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(31B01B5C)=0 - mempool cleanup
Mar 26 22:57:07.419: //57/4F67CF3C806A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2B62F434, Tag=0x0, Call Id=57,
Mar 26 22:57:07.419: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 26 22:57:07.419: :cc_free_feature_vsa freeing 324649B0
Mar 26 22:57:07.419:  vsacount in free is 0
CC.orange.cd#
I was going to say what Daniel just said now. Looks like you didnt enable debug ccsip messages. The cause code of 102 means recovery on timer expiry which means that the far end is not responding to the INVITE sent by the gateway...Please send us debug ccsip messages and we will confirm this
daniel.bloom
I don't see any debug ccsip message traces in the last debug. Can you redo the last call trace with the debug ccsip message trace active?
Dear Daniel,
Below the requested logs,
thx
CC.orange.cd#debug ccsip message
SIP Call messages tracing is enabled
CC.orange.cd#debug voip ccapi inout
Mar 26 23:31:43.887: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:10.1.138.32:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.153.130:5060;branch=z9hG4bK317BB
To:
Date: Tue, 26 Mar 2013 23:31:43 GMT
Call-ID: A64FEBB7-95A311E2-8002ADF3-E0856EFD
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1364340703
CSeq: 3 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 26 23:31:43.903: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:10.1.153.144:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.153.130:5060;branch=z9hG4bK411E3
To:
Call-ID: A67A07D9-95A311E2-8003ADF3-E0856EFD
Max-Forwards: 70
CSeq: 3 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 26 23:31:43.907: //9/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
voip ccapi inout debugging is on
CC.orange.cd#SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 10.1.153.130:5060;branch=z9hG4bK411E3;received=10.1.153.132
To: ;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-805
CSeq: 3 REGISTER
Expires: 1800
Contact: ;expires=1800
Content-Length: 0
Mar 26 23:31:44.387: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Tue, 26 Mar 2013 23:31:44 GMT
Max-Forwards: 70
Timestamp: 1364340704
CSeq: 3 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 26 23:31:45.387: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Tue, 26 Mar 2013 23:31:45 GMT
Max-Forwards: 70
Timestamp: 1364340705
CSeq: 3 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 26 23:31:47.387: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Tue, 26 Mar 2013 23:31:47 GMT
Max-Forwards: 70
Timestamp: 1364340707
CSeq: 3 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 26 23:31:49.979: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
From: ;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-806
To:
Call-ID: 00274926-BE0F-1151-8B6C-8F99010AAA77-564@10.1.153.144
CSeq: 1364340805 OPTIONS
Content-Length: 0
Via: SIP/2.0/UDP 10.1.153.144:5060;branch=z9hG4bK003F5C64-3045-1152-8B6C-8F99010AAA77
Max-Forwards: 0
Mar 26 23:31:49.979: //10/2ACD2701800E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: ;tag=405EC-12DB
Date: Tue, 26 Mar 2013 23:31:49 GMT
Content-Length: 450
v=0
o=CiscoSystemsSIP-GW-UserAgent 6432 6020 IN IP4 10.1.153.130
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Mar 26 23:31:51.387: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Tue, 26 Mar 2013 23:31:51 GMT
Max-Forwards: 70
Timestamp: 1364340711
CSeq: 3 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 26 23:31:54.951: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:90819890007@10.1.153.130:5060 SIP/2.0
From: sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-808
To: <90819890007>
Call-ID: 00274926-BE0F-1151-8B6C-8F99010AAA77-565@10.1.153.144
CSeq: 1 INVITE
Content-Length: 293
Via: SIP/2.0/UDP 10.1.153.144:5060;branch=z9hG4bK00274958-BE0F-1151-8B6C-8F99010AAA77-354
Contact: <5004>
Max-Forwards: 69
X-Genesys-CallUUID: 016E6N5U1S8L32RCHUCG22LAES00002L
X-ISCC-CofId: location=KINSHASA;cofid=1114
Min-SE: 90
v=0
o=- 1364312841 1 IN IP4 172.16.30.25
t=0 0
m=audio 45434 RTP/AVP 8 101
a=sendrecv
a=alt:1 2 : ZYZT4eFE LJ8vQabu 192.168.42.21 45434
a=alt:2 1 : F0tTQU+Y oa0Ahsp2 172.16.30.25 45434
a=fmtp:101 0-15
Mar 26 23:31:54.951: //-1/2DC3D1D1800F/CCAPI/cc_api_display_ie_subfields:
   cisco-username=5004
   cisco-ani=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-808
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Mar 26 23:31:54.951: //-1/2DC3D1D1800F/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x314538B4, Call Info(
   Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-808,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=11
Mar 26 23:31:54.951: //-1/2DC3D1D1800F/CCAPI/ccCheckClipClir:
   In: Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-808(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Mar 26 23:31:54.955: //-1/2DC3D1D1800F/CCAPI/ccCheckClipClir:
   Out: Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-808(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Mar 26 23:31:54.955: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 26 23:31:54.955: :cc_get_feature_vsa malloc success
Mar 26 23:31:54.955:  cc_get_feature_vsa count is 1
Mar 26 23:31:54.955: :FEATURE_VSA attributes are: feature_name:0,feature_time:741949888,feature_id:3
Mar 26 23:31:54.955: //11/2DC3D1D1800F/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Mar 26 23:31:54.955: //11/2DC3D1D1800F/CCAPI/cc_process_call_setup_ind:
   Event=0x2C1CE7C0
Mar 26 23:31:54.955: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Mar 26 23:31:54.955: //11/2DC3D1D1800F/CCAPI/ccCallSetContext:
   Context=0x2CC92AE8
   >>>>CCAPI handed cid 11 with tag 3 to app "_ManagedAppProcess_Default"
Mar 26 23:31:54.955: //11/2DC3D1D1800F/CCAPI/ccCallProceeding:
Mar 26 23:31:54.955: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
   mempool not found from usrContainer(31F2E320)
Mar 26 23:31:54.955: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
   Mempool(2BF96054) created in usrContainer(31F2E320)
Mar 26 23:31:54.955: //11/2DC3D1D1800F/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x2CC93FF8, Progress Indication=NULL(0)
Mar 26 23:31:54.955: //11/2DC3D1D1800F/CCAPI/ccCheckClipClir:
   Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-808(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Guid=2DC3D1D1-95A4-11E2-800F-ADF3E0856EFD, Outgoing Dial-peer=3
Mar 26 23:31:54.955: //11/2DC3D1D1800F/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=5004
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=90819890007
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Mar 26 23:31:54.955: //11/2DC3D1D1800F/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x314538B4, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-808,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Mar 26 23:31:54.955:  cc_get_feature_vsa count is 2
Mar 26 23:31:54.955: :FEATURE_VSA attributes are: feature_name:0,feature_time:741949664,feature_id:4
Mar 26 23:31:54.955: //12/2DC3D1D1800F/CCAPI/ccIFCallSetupRequestPrivate:
Mar 26 23:31:54.955: //12/2DC3D1D1800F/CCAPI/ccCallSetContext:
   Context=0x2CC93FA8
Mar 26 23:31:54.955: //11/2DC3D1D1800F/CCAPI/ccSaveDialpeerTag:
Mar 26 23:31:54.959: //12/2DC3D1D1800F/CCAPI/cc_api_call_proceeding:
   Interface=0x314538B4, Progress Indication=NULL(0)
Mar 26 23:31:54.959: //11/2DC3D1D1800F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <90819890007>
Date: Tue, 26 Mar 2013 23:31:54 GMT
CSeq: 1 INVITE
Content-Length: 0
Mar 26 23:31:54.959: //12/2DC3D1D1800F/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:90819890007@10.1.138.32:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.153.130:5060;branch=z9hG4bK513F7
To: <90819890007>
Call-ID: 2DC50A21-95A411E2-8015ADF3-E0856EFD@10.1.153.130
Min-SE:  1800
Cisco-Guid: 0767807953-2510557666-2148511219-3766841085
CSeq: 101 INVITE
Timestamp: 1364340714
Contact: <5004>
Expires: 180
Max-Forwards: 68
P-Asserted-Identity: <5004>
Content-Disposition: session;handling=required
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 9120 3624 IN IP4 10.1.153.130
s=SIP Call
t=0 0
m=audio 26118 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=fmtp:101 0-15
a=ptime:20
Mar 26 23:31:54.971: //12/2DC3D1D1800F/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.1.153.130:5060;received=10.1.149.61;branch=z9hG4bK513F7
Contact: <10.1.138.32:5060>
CSeq: 101 INVITE
To: <90819890007>;tag=ztesip7g-m0vDKGYhjZrzJo8WSi7kN-J1H0XaPjZuplD0.29
Mar 26 23:31:54.971: //12/2DC3D1D1800F/CCAPI/cc_api_call_disconnected:
   Cause Value=1, Interface=0x314538B4, Call Id=12
   Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
Mar 26 23:31:54.971: //11/2DC3D1D1800F/CCAPI/ccCallReleaseResources:
Mar 26 23:31:54.971: //12/2DC3D1D1800F/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=12
Mar 26 23:31:54.971: //12/2DC3D1D1800F/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Mar 26 23:31:54.971: //12/2DC3D1D1800F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x314538B4, Tag=0x0, Call Id=12,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
Mar 26 23:31:54.971: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 26 23:31:54.971: :cc_free_feature_vsa freeing 2C3940D8
Mar 26 23:31:54.971:  vsacount in free is 1
Mar 26 23:31:54.971: //11/2DC3D1D1800F/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Mar 26 23:31:54.971: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
   data = 2C91FF78
Mar 26 23:31:54.971: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(2BF96054)=0 - mempool cleanup
Mar 26 23:31:54.975: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:90819890007@10.1.138.32:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Mar 26 23:31:54.975: //11/2DC3D1D1800F/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <90819890007>;tag=41970-1FB2
CSeq: 1 INVITE
Reason: Q.850;cause=1
Content-Length: 0
Received:
ACK sip:90819890007@10.1.153.130:5060 SIP/2.0
CSeq: 1 ACK
Max-Forwards: 69
Content-Length: 0
Mar 26 23:31:54.979: //11/2DC3D1D1800F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x314538B4, Tag=0x0, Call Id=11,
Mar 26 23:31:54.979: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 26 23:31:54.979: :cc_free_feature_vsa freeing 2C3941B8
Mar 26 23:31:54.979:  vsacount in free is 0
Mar 26 23:31:55.387: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Tue, 26 Mar 2013 23:31:55 GMT
Max-Forwards: 70
Timestamp: 1364340715
CSeq: 3 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 26 23:31:59.387: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Tue, 26 Mar 2013 23:31:59 GMT
Max-Forwards: 70
Timestamp: 1364340719
CSeq: 3 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 26 23:32:03.387: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Tue, 26 Mar 2013 23:32:03 GMT
Max-Forwards: 70
Timestamp: 1364340723
CSeq: 3 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 26 23:32:07.387: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Tue, 26 Mar 2013 23:32:07 GMT
Max-Forwards: 70
Timestamp: 1364340727
CSeq: 3 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 26 23:32:10.319: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:900819890007@10.1.153.130:5060 SIP/2.0
From: sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-811
To: <900819890007>
Call-ID: 00274926-BE0F-1151-8B6C-8F99010AAA77-567@10.1.153.144
CSeq: 1 INVITE
Content-Length: 293
Via: SIP/2.0/UDP 10.1.153.144:5060;branch=z9hG4bK00274958-BE0F-1151-8B6C-8F99010AAA77-360
Contact: <5004>
Max-Forwards: 69
X-Genesys-CallUUID: 016E6N5U1S8L32RCHUCG22LAES00002M
X-ISCC-CofId: location=KINSHASA;cofid=1116
Min-SE: 90
v=0
o=- 1364312860 1 IN IP4 172.16.30.25
t=0 0
m=audio 16742 RTP/AVP 8 101
a=sendrecv
a=alt:1 2 : BJPqXgg4 vxtJy8B3 192.168.42.21 16742
a=alt:2 1 : NgsUmZTY 0r6Pim/i 172.16.30.25 16742
a=fmtp:101 0-15
Mar 26 23:32:10.323: //-1/36ECCB728016/CCAPI/cc_api_display_ie_subfields:
   cisco-username=5004
   cisco-ani=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-811
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=sip:900819890007@10.1.153.130:5060
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Mar 26 23:32:10.323: //-1/36ECCB728016/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-811,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=sip:900819890007@10.1.153.130:5060(TON=Unknown, NPI=Unknown),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=13
Mar 26 23:32:10.323: //-1/36ECCB728016/CCAPI/ccCheckClipClir:
   In: Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-811(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-811(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Mar 26 23:32:10.323: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 26 23:32:10.323: :cc_get_feature_vsa malloc success
Mar 26 23:32:10.323:  cc_get_feature_vsa count is 1
Mar 26 23:32:10.323: :FEATURE_VSA attributes are: feature_name:0,feature_time:741949888,feature_id:5
Mar 26 23:32:10.323: //13/36ECCB728016/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Mar 26 23:32:10.323: //13/36ECCB728016/CCAPI/cc_process_call_setup_ind:
   Event=0x2C1CE7C0
Mar 26 23:32:10.323: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 900819890007
Mar 26 23:32:10.323: //13/36ECCB728016/CCAPI/ccCallSetContext:
   Context=0x2CC95468
Mar 26 23:32:10.327: //13/36ECCB728016/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 13 with tag 3 to app "_ManagedAppProcess_Default"
Mar 26 23:32:10.327: //13/36ECCB728016/CCAPI/ccCallProceeding:
Mar 26 23:32:10.327: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
   mempool not found from usrContainer(31F2E258)
Mar 26 23:32:10.327: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
   Mempool(31A456E8) created in usrContainer(31F2E258)
Mar 26 23:32:10.327: //13/36ECCB728016/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x2CC96978, Progress Indication=NULL(0)
Mar 26 23:32:10.327: //13/36ECCB728016/CCAPI/ccCheckClipClir:
   Destination Pattern=.T, Called Number=900819890007, Digit Strip=FALSE
   Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-811(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=900819890007(TON=Unknown, NPI=Unknown),
   Guid=36ECCB72-95A4-11E2-8016-ADF3E0856EFD, Outgoing Dial-peer=3
Mar 26 23:32:10.327: //13/36ECCB728016/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=5004
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=900819890007
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Mar 26 23:32:10.327: //13/36ECCB728016/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=sip:5004@10.1.153.144;tag=00274944-BE0F-1151-8B6C-8F99010AAA77-811,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=900819890007(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Mar 26 23:32:10.327: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 26 23:32:10.327: :cc_get_feature_vsa malloc success
Mar 26 23:32:10.327:  cc_get_feature_vsa count is 2
Mar 26 23:32:10.327: :FEATURE_VSA attributes are: feature_name:0,feature_time:741949664,feature_id:6
Mar 26 23:32:10.327: //14/36ECCB728016/CCAPI/ccIFCallSetupRequestPrivate:
Mar 26 23:32:10.327: //14/36ECCB728016/CCAPI/ccCallSetContext:
   Context=0x2CC96928
Mar 26 23:32:10.327: //13/36ECCB728016/CCAPI/ccSaveDialpeerTag:
Mar 26 23:32:10.327: //14/36ECCB728016/CCAPI/cc_api_call_proceeding:
Mar 26 23:32:10.331: //13/36ECCB728016/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <900819890007>
Date: Tue, 26 Mar 2013 23:32:10 GMT
CSeq: 1 INVITE
Content-Length: 0
Mar 26 23:32:10.331: //14/36ECCB728016/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:900819890007@10.1.138.32:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.153.130:5060;branch=z9hG4bK6BB6
To: <900819890007>
Call-ID: 36EE03C2-95A411E2-801CADF3-E0856EFD@10.1.153.130
Min-SE:  1800
Cisco-Guid: 0921488242-2510557666-2148969971-3766841085
CSeq: 101 INVITE
Timestamp: 1364340730
Contact: <5004>
Expires: 180
Max-Forwards: 68
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 9507 4430 IN IP4 10.1.153.130
s=SIP Call
t=0 0
m=audio 30598 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
Mar 26 23:32:10.343: //14/36ECCB728016/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.1.153.130:5060;received=10.1.149.61;branch=z9hG4bK6BB6
CSeq: 101 INVITE
To: <900819890007>;tag=ztesipCmzt_U-mYMr.30
Mar 26 23:32:10.343: //14/36ECCB728016/CCAPI/cc_api_call_disconnected:
   Cause Value=1, Interface=0x314538B4, Call Id=14
Mar 26 23:32:10.343: //13/36ECCB728016/CCAPI/ccCallReleaseResources:
Mar 26 23:32:10.343: //14/36ECCB728016/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=14
Mar 26 23:32:10.343: //14/36ECCB728016/CCAPI/ccCallDisconnect:
Mar 26 23:32:10.347: //14/36ECCB728016/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x314538B4, Tag=0x0, Call Id=14,
Mar 26 23:32:10.347: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 26 23:32:10.347: :cc_free_feature_vsa freeing 2C3940D8
Mar 26 23:32:10.347:  vsacount in free is 1
Mar 26 23:32:10.347: //13/36ECCB728016/CCAPI/ccCallDisconnect:
Mar 26 23:32:10.347: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
   data = 2C91FCB8
Mar 26 23:32:10.347: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(31A456E8)=0 - mempool cleanup
Mar 26 23:32:10.347: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:900819890007@10.1.138.32:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Mar 26 23:32:10.347: //13/36ECCB728016/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <900819890007>;tag=4557C-6BD
CSeq: 1 INVITE
Content-Length: 0
Mar 26 23:32:10.351: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:900819890007@10.1.153.130:5060 SIP/2.0
CSeq: 1 ACK
Max-Forwards: 69
Content-Length: 0
Mar 26 23:32:10.351: //13/36ECCB728016/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x314538B4, Tag=0x0, Call Id=13,
Mar 26 23:32:10.351: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 26 23:32:10.351: :cc_free_feature_vsa freeing 2C3941B8
Mar 26 23:32:10.351:  vsacount in free is 0
Mar 26 23:32:11.387: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Tue, 26 Mar 2013 23:32:11 GMT
Max-Forwards: 70
Timestamp: 1364340731
CSeq: 3 REGISTER
Contact:
Expires:  3600
Supported: path
Conte
CC.orange.cd#nt-Length: 0
Mar 26 23:32:14.891: //8/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 408 Request Timeout
Via: SIP/2.0/UDP 10.1.153.130:5060;received=10.1.149.61;branch=z9hG4bK317BB
To: ;tag=ztesipXu1KwG8R.30
CSeq: 3 REGISTER
This device 10.1.138.32 is saying that the number called 900819890007 doesnt not exist on it, or doesnt know how to route that number,,
Received:
CSeq: 101 INVITE
Check that you are sending the right digit to the Provider
Dear all,
I've adjusted the called number, now I'm receiving disconnect call cause : 16
Once I'm calling, after 10 sec the call is established and  hung up after 5 sec of busy signal.
below the required logs, kindly advise if the problem from my side or Sip provider
Mar 27 20:58:10.162: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:00243844735719@10.1.153.130:5060 SIP/2.0
From: sip:5004@10.1.153.144;tag=0045BB5E-FB51-1152-98B4-8F99010AAA77-880
To: <00243844735719>
Call-ID: 0045BB22-FB51-1152-98B4-8F99010AAA77-630@10.1.153.144
CSeq: 1 INVITE
Content-Length: 294
Via: SIP/2.0/UDP 10.1.153.144:5060;branch=z9hG4bK0045BC9E-FB51-1152-98B4-8F99010AAA77-891
Contact: <5004>
Max-Forwards: 69
X-Genesys-CallUUID: 01R6FLNRA48L565KHUCG22LAES00004B
X-ISCC-CofId: location=KINSHASA;cofid=1300
Min-SE: 90
v=0
o=- 1364395414 1 IN IP4 172.16.30.25
t=0 0
m=audio 27062 RTP/AVP 8 101
a=sendrecv
a=alt:1 2 : tiv8YPs/ B0ycbyge 192.168.42.191 27062
a=alt:2 1 : Ujpenxpr rNSG6s3X 172.16.30.25 27062
a=fmtp:101 0-15
Mar 27 20:58:10.166: //-1/DDC65FA0832C/CCAPI/cc_api_display_ie_subfields:
   cisco-username=5004
   cisco-ani=sip:5004@10.1.153.144;tag=0045BB5E-FB51-1152-98B4-8F99010AAA77-880
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=sip:00243844735719@10.1.153.130:5060
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Mar 27 20:58:10.166: //-1/DDC65FA0832C/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x314FB134, Call Info(
   Calling Number=sip:5004@10.1.153.144;tag=0045BB5E-FB51-1152-98B4-8F99010AAA77-880,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=sip:00243844735719@10.1.153.130:5060(TON=Unknown, NPI=Unknown),
   Incoming Dial-peer=4, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=764
Mar 27 20:58:10.166: //-1/DDC65FA0832C/CCAPI/ccCheckClipClir:
   In: Calling Number=sip:5004@10.1.153.144;tag=0045BB5E-FB51-1152-98B4-8F99010AAA77-880(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=sip:5004@10.1.153.144;tag=0045BB5E-FB51-1152-98B4-8F99010AAA77-880(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Mar 27 20:58:10.166: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 27 20:58:10.166: :cc_get_feature_vsa malloc success
Mar 27 20:58:10.166:  cc_get_feature_vsa count is 1
Mar 27 20:58:10.166: :FEATURE_VSA attributes are: feature_name:0,feature_time:750403696,feature_id:70
Mar 27 20:58:10.166: //764/DDC65FA0832C/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Mar 27 20:58:10.166: //764/DDC65FA0832C/CCAPI/cc_process_call_setup_ind:
   Event=0x2C0F6E78
Mar 27 20:58:10.166: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 00243844735719
Mar 27 20:58:10.166: //764/DDC65FA0832C/CCAPI/ccCallSetContext:
   Context=0x32312DD0
   >>>>CCAPI handed cid 764 with tag 4 to app "_ManagedAppProcess_Default"
Mar 27 20:58:10.166: //764/DDC65FA0832C/CCAPI/ccCallProceeding:
Mar 27 20:58:10.166: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
   mempool not found from usrContainer(32027B18)
Mar 27 20:58:10.166: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
   Mempool(30A63C08) created in usrContainer(32027B18)
Mar 27 20:58:10.170: //764/DDC65FA0832C/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=5, Params=0x323142E0, Progress Indication=NULL(0)
Mar 27 20:58:10.170: //764/DDC65FA0832C/CCAPI/ccCheckClipClir:
   Destination Pattern=.T, Called Number=00243844735719, Digit Strip=FALSE
   Calling Number=sip:5004@10.1.153.144;tag=0045BB5E-FB51-1152-98B4-8F99010AAA77-880(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=00243844735719(TON=Unknown, NPI=Unknown),
   Guid=DDC65FA0-9657-11E2-832C-80806980C006, Outgoing Dial-peer=5
Mar 27 20:58:10.170: //764/DDC65FA0832C/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=5004
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=00243844735719
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Mar 27 20:58:10.170: //764/DDC65FA0832C/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x314FB134, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=sip:5004@10.1.153.144;tag=0045BB5E-FB51-1152-98B4-8F99010AAA77-880,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=00243844735719(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=5, Call Count On=FALSE,
Mar 27 20:58:10.170: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 27 20:58:10.170: :cc_get_feature_vsa malloc success
Mar 27 20:58:10.170:  cc_get_feature_vsa count is 2
Mar 27 20:58:10.170: :FEATURE_VSA attributes are: feature_name:0,feature_time:750403472,feature_id:71
Mar 27 20:58:10.170: //765/DDC65FA0832C/CCAPI/ccIFCallSetupRequestPrivate:
Mar 27 20:58:10.170: //765/DDC65FA0832C/CCAPI/ccCallSetContext:
   Context=0x32314290
Mar 27 20:58:10.170: //764/DDC65FA0832C/CCAPI/ccSaveDialpeerTag:
Mar 27 20:58:10.170: //765/DDC65FA0832C/CCAPI/cc_api_call_proceeding:
   Interface=0x314FB134, Progress Indication=NULL(0)
Mar 27 20:58:10.174: //764/DDC65FA0832C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 27 Mar 2013 20:58:10 GMT
CSeq: 1 INVITE
Content-Length: 0
Mar 27 20:58:10.174: //765/DDC65FA0832C/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:00243844735719@10.1.138.32:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.153.130:5060;branch=z9hG4bK1132DA
Call-ID: DDC797F0-965711E2-83328080-6980C006@10.1.153.130
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3720765344-2522288610-2200731776-1770045446
CSeq: 101 INVITE
Timestamp: 1364417890
Contact: <5004>
Expires: 180
Max-Forwards: 68
Content-Length: 191
v=0
o=CiscoSystemsSIP-GW-UserAgent 4367 7349 IN IP4 10.1.153.130
s=SIP Call
t=0 0
m=audio 25316 RTP/AVP 8
a=ptime:20
Mar 27 20:58:10.378: //765/DDC65FA0832C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Via: SIP/2.0/UDP 10.1.153.130:5060;received=10.1.149.61;branch=z9hG4bK1132DA
Mar 27 20:58:14.594: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
From: ;tag=0045BB5E-FB51-1152-98B4-8F99010AAA77-881
To:
Call-ID: 0045BB22-FB51-1152-98B4-8F99010AAA77-631@10.1.153.144
CSeq: 1364417987 OPTIONS
Content-Length: 0
Via: SIP/2.0/UDP 10.1.153.144:5060;branch=z9hG4bK005A68D8-5DC3-1153-98B4-8F99010AAA77
Max-Forwards: 0
Mar 27 20:58:14.594: //766/E06AA4058333/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: ;tag=17BC3D0-1163
Date: Wed, 27 Mar 2013 20:58:14 GMT
Content-Length: 450
v=0
o=CiscoSystemsSIP-GW-UserAgent 2568 6330 IN IP4 10.1.153.130
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Mar 27 20:58:42.178: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:00243844735719@10.1.153.130:5060 SIP/2.0
CSeq: 1 CANCEL
Content-Length: 0
Max-Forwards: 70
Mar 27 20:58:42.178: //764/DDC65FA0832C/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x314FB134, Call Id=764
   Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Mar 27 20:58:42.178: //765/DDC65FA0832C/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Mar 27 20:58:42.182: //765/DDC65FA0832C/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=FALSE, Cause Value=16)
Mar 27 20:58:42.182: //764/DDC65FA0832C/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Mar 27 20:58:42.182: //764/DDC65FA0832C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 27 Mar 2013 20:58:42 GMT
CSeq: 1 CANCEL
Content-Length: 0
Mar 27 20:58:42.182: //765/DDC65FA0832C/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:00243844735719@10.1.138.32:5060 SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1364417922
Reason: Q.850;cause=16
Content-Length: 0
Sent:
SIP/2.0 487 Request Cancelled
To: <00243844735719>;tag=17C2F94-4B9
CSeq: 1 INVITE
Content-Length: 0
Mar 27 20:58:42.182: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:00243844735719@10.1.153.130:5060 SIP/2.0
CSeq: 1 ACK
Max-Forwards: 69
Content-Length: 0
Mar 27 20:58:42.182: //764/DDC65FA0832C/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x314FB134, Tag=0x0, Call Id=764,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Mar 27 20:58:42.186: //764/DDC65FA0832C/CCAPI/cc_api_call_disconnect_done:
Mar 27 20:58:42.186: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 27 20:58:42.186: :cc_free_feature_vsa freeing 2CBA4068
Mar 27 20:58:42.186:  vsacount in free is 1
Mar 27 20:58:42.190: //765/DDC65FA0832C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length:    0
Mar 27 20:58:42.190: //765/DDC65FA0832C/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x314FB134, Tag=0x0, Call Id=765,
Mar 27 20:58:42.190: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 27 20:58:42.190: :cc_free_feature_vsa freeing 2CBA3F88
Mar 27 20:58:42.190:  vsacount in free is 0
Mar 27 20:58:42.190: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
   data = 2C7F7960
Mar 27 20:58:42.190: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(30A63C08)=0 - mempool cleanup
CC.orange.cd(config-dial-peer)#
CC.orange.cd#
Mar 27 20:58:55.618: %SYS-5-CONFIG_I: Configured from console by orange on vty0 (172.16.30.25)
Mar 27 20:59:14.598: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
From: ;tag=0045BB5E-FB51-1152-98B4-8F99010AAA77-883
To:
Call-ID: 0045BB22-FB51-1152-98B4-8F99010AAA77-633@10.1.153.144
CSeq: 1364418047 OPTIONS
Content-Length: 0
Via: SIP/2.0/UDP 10.1.153.144:5060;branch=z9hG4bK005B104E-5DFF-1153-98B4-8F99010AAA77
Max-Forwards: 0
Mar 27 20:59:14.602: //767/042E85948334/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: ;tag=17CAE38-1FFB
Date: Wed, 27 Mar 2013 20:59:14 GMT
Content-Length: 450
v=0
o=CiscoSystemsSIP-GW-UserAgent 2049 5836 IN IP4 10.1.153.130
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Mar 27 20:59:27.742: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.1.153.130:5060;branch=z9hG4bK11469A
To:
Date: Wed, 27 Mar 2013 20:59:27 GMT
Call-ID: 6B09D3A-961E11E2-80038080-6980C006
Max-Forwards: 70
Timestamp: 1364417967
CSeq: 129 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 20:59:28.242: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 27 Mar 2013 20:59:28 GMT
Max-Forwards: 70
Timestamp: 1364417968
CSeq: 129 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 20:59:29.242: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 27 Mar 2013 20:59:29 GMT
Max-Forwards: 70
Timestamp: 1364417969
CSeq: 129 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 20:59:31.242: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 27 Mar 2013 20:59:31 GMT
Max-Forwards: 70
Timestamp: 1364417971
CSeq: 129 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 20:59:35.242: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 27 Mar 2013 20:59:35 GMT
Max-Forwards: 70
Timestamp: 1364417975
CSeq: 129 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 20:59:39.242: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 27 Mar 2013 20:59:39 GMT
Max-Forwards: 70
Timestamp: 1364417979
CSeq: 129 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 20:59:43.242: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 27 Mar 2013 20:59:43 GMT
Max-Forwards: 70
Timestamp: 1364417983
CSeq: 129 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 20:59:47.242: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 27 Mar 2013 20:59:47 GMT
Max-Forwards: 70
Timestamp: 1364417987
CSeq: 129 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 20:59:51.242: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 27 Mar 2013 20:59:51 GMT
Max-Forwards: 70
Timestamp: 1364417991
CSeq: 129 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 20:59:55.242: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 27 Mar 2013 20:59:55 GMT
Max-Forwards: 70
Timestamp: 1364417995
CSeq: 129 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 20:59:59.242: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 27 Mar 2013 20:59:59 GMT
Max-Forwards: 70
Timestamp: 1364417999
CSeq: 129 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 21:00:14.606: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
From: ;tag=0045BB5E-FB51-1152-98B4-8F99010AAA77-884
To:
Call-ID: 0045BB22-FB51-1152-98B4-8F99010AAA77-634@10.1.153.144
CSeq: 1364418107 OPTIONS
Content-Length: 0
Via: SIP/2.0/UDP 10.1.153.144:5060;branch=z9hG4bK005BDC36-5E3B-1153-98B4-8F99010AAA77
Max-Forwards: 0
Mar 27 21:00:14.610: //769/27F3A0A58335/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: ;tag=17D98A0-2EC
Date: Wed, 27 Mar 2013 21:00:14 GMT
Content-Length: 450
v=0
o=CiscoSystemsSIP-GW-UserAgent 8216 2732 IN IP4 10.1.153.130
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Mar 27 21:00:52.466: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.1.153.130:5060;branch=z9hG4bK1152455
To:
Date: Wed, 27 Mar 2013 21:00:52 GMT
Call-ID: B93DA6C4-963A11E2-81C88080-6980C006
Max-Forwards: 70
Timestamp: 1364418052
CSeq: 61 REGISTER
Contact:
Expires:  3600
Supported: path
Authorization: Digest username="orange",realm="orange.cd",uri="sip:10.1.138.32:5060",response="",nonce=""
Content-Length: 0
Mar 27 21:00:52.966: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Max-Forwards: 70
CSeq: 61 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 21:00:53.966: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 27 Mar 2013 21:00:53 GMT
Max-Forwards: 70
Timestamp: 1364418053
CSeq: 61 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 21:00:55.966: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 27 Mar 2013 21:00:55 GMT
Max-Forwards: 70
Timestamp: 1364418055
CSeq: 61 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 21:00:59.966: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 27 Mar 2013 21:00:59 GMT
Max-Forwards: 70
Timestamp: 1364418059
CSeq: 61 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 21:01:03.966: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 27 Mar 2013 21:01:03 GMT
Max-Forwards: 70
Timestamp: 1364418063
CSeq: 61 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 21:01:07.966: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 27 Mar 2013 21:01:07 GMT
Max-Forwards: 70
Timestamp: 1364418067
CSeq: 61 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
Mar 27 21:01:11.966: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 27 Mar 2013 21:01:11 GMT
Max-Forwards: 70
Timestamp: 1364418071
CSeq: 61 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
