cisco software support service
morten_krog
Is it mandatory to have the Software Support service on the phones registered on a CUCM?
and what happens if you do not have Cisco Software Support Service on all device licenses in CUCM?
(what rights do you lose)
All my License type is of course in compliance in my PLM
Hi Morten,
As far as I know, the call manager support subscription against the number of licenses on your platform. if you do not have any kind of support subscription, you will not get support from Cisco TAC or not able to upgrade to the new versions.
with respect to the phone itself, the phones still work in the set up as long as you have sufficient/appropriate user licenses in your call manager. but you will not be able to raise RMA against the phone if you find it faulty.
Shalid
Aman Soi
You need Software support service [SWSS] while doing  major upgrades say from CUCM 10 to 11. So, once you do major upgrades , you need to have user licenses for that upgraded version.
Suppose before up gradation you have 100 CUWL standard licenses and SWSS for 80 . After, you do upgrade, only 80 phones with 80 CUWL licenses would be working .
Also, while placing the order , you could mention only 80 to be ordered.
regds,
aman
HARIS_HUSSAIN
Look at below link
https://www.cisco.com/c/dam/en_us/services/portfolio/documents/support-service-qa.pdf.
So basically what you loose is
1) Cisco TAC Support :- Required to analyze any complicated issues or recognize and fix software bugs.
2) Upgrades :- Essential as after few year the current version might be End Of sale/Support and upgrade would be necessary.
Haris
Please rate and mark correct
