Bookmark
Subscribe
4071
Cisco SRST - different dial-patterns
Daniov1
Hi ,
I have SRST gateway with 2 PRI .
Each of the PRI connected to different provider.
SRST configured with SIP protocol ,Each of the PRI has a different DID.
voice register global
 defualt mode
 no allow-hash-in-dn
 max-dn 600
 max-pool 500
 dialplan-pattern 1 6834... extension-lenght 4
 dialplan-pattern 2 683454... extension-lenght 4
when calling to 6834... it's works properly, when calling to 683454... it's not working.
If I will change the configuration that 683454... will be "dialplan-pattern 1" it's will work propely but 6834... isn't.
Any suggest?
14 Replies 14
Try the following
dialplan-pattern 1 6834[0-4].. extension-lenght 4
dialplan-pattern 2 6834[6-9].. extension-lenght 4
dialplan-pattern 3 683454... extension-lenght 4
Hi ,
Thank you for your response.
I was wrong.
DID 1 is 6404...
DID 2 is 733294...
 defualt mode
 no allow-hash-in-dn
 max-dn 600
 max-pool 500
 dialplan-pattern 1 6404... extension-lenght 4
 dialplan-pattern 2 733294... extension-lenght 4
when calling to 6404... it's works properly, when calling to 733294... it's not working.
If I will change the configuration that 733294... will be "dialplan-pattern 1" it's will work propely but 6404... isn't.
Check the command show dialpeer voice summary. For each extension you
should see 3 dialpeers. For example, extension 4001, you should see the
following dialpeers
4001$
6404001$
733294001$
**** Please remember to rate useful posts
The issue is with incoming calls from PSTN to Phone registered to SRST when the second dialplan-pattern not match, just dialplan-pattern 1 match.
attached is "show dial-peer voice sammery"
Your dialplan-pattern 2 is 733294... and your dial-peer voice 30 is 73329....
I wonder if making them match would solve the problem. Spitballing here...
Maren
Hi ,
Thanks for your response .
It's not the issue , if I will configure the dialplan-pattern 1 for 733294.. it's will work .
The issue is that the second dialplan-pattern (2) isn't work no matter what I define.
Can you try it using voice translation-rule instead of using dialplan-pattern? Here is the configuration:
voice translation-rule 1
 rule 1 /^640\(4...\)$/ /\1/
voice translation-rule 2
 rule 1 /^73329\(4...\)$/ /\1/
voice translation-profile PRI1-PSTN-IN
 translate called 1
voice translation-profile PRI2-PSTN-IN
 translate called 2
dial-peer voice 9001 pots
 description # Incoming Calls on PRI-1 #
 translation-profile incoming PRI1-PSTN-IN
 incoming called-number 6404...
 direct-inward-dial
 port 0/0/1:23 --------------------------------------> Change PRI Port number according to your setup.
dial-peer voice 9002 pots
 description # Incoming Calls on PRI-2 #
 translation-profile incoming PRI2-PSTN-IN
 incoming called-number 733294...
 direct-inward-dial
 port 0/0/2:23 --------------------------------------> Change PRI Port number according to your setup.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Hi ,
Thanks for your response.
This configuration working in SRST mode , but i have a problem to configure it because incoming calls which route to CUCM needs to forward all the pattern include 6404... (the cucm discard digits) and if i will configure the below dial-peer 9001 will match and discard the first three digits and i can't forward just 4 digits to CUCM because i have a lot a manipulations on CUCM.
In SRST mode i need to forward 4 digit using dialpeer pots.
In CUCM mode i need to forward digit all using dialpeer voip.
Danielo.
Do you just want to forward 6404... to CUCM or you want to forward both 6404... and 733294...?
I want forward both 6404... and 733294...to cucm.
Danielo.
What protocol are you using between SRST Router and CUCM for PRI lines?
CUCM mode:
Provider-> E1 PRI -> VGW -> SIP -> CUCM ->sip ip phone
SRST mode:
Provider -> E1 PRI -> VGW -> sip ip phone.
Danielo.
Danielo.
I am assuming that you have unique 4-digit numbers in DID range 6404... and 733294... for example 6404[1-4]XX and 733294[5-8]XX; then here is the configuration you can try for non-SRST and SRST mode:
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class server-group 1000
ipv4 10.10.200.21 preference 1--------------------------------------> Change CUCM IP according to your setup.
ipv4 10.10.200.22 preference 2--------------------------------------> Change CUCM IP according to your setup.
description ** CUCM SERVER GROUP **
 rule 1 /^640\(4[1-4]..\)$/ /\1/
 rule 1 /^73329\(4[5-8]..\)$/ /\1/
voice translation-rule 3
 rule 1 /^\(4[1-4]..\)$/ /640\1/
 rule 2 /^\(4[5-8]..\)$/ /73329\1/
 translate called 1
 translate called 2
voice translation-profile CUCM-OUT
 translate called 3
dial-peer voice 1001 voip
preference 1
description ** OUTBOUND CALLS TO CUCM CLUSTER **
translation-profile outgoing CUCM-OUT
destination-pattern 4...$
session protocol sipv2
session server-group 1000
voice-class codec 1
voice-class sip early-offer forced
voice-class sip bind control source-interface GigabitEthernet0/0/0-------> Change interface according to your setup.
voice-class sip bind media source-interface GigabitEthernet0/0/0-------> Change interface according to your setup.
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
 direct-inward-dial
 direct-inward-dial
During normal operation, the dial-peer 1001 will be used to prefix the digits and send the calls to CUCM. During SRST mode, the IP Phones will register to SRST router with 4-digit DN and it will create dial peers automatically.
I think dialpeer 30 is matched before dial-pattern. SIP registered dns will
have dialpeers from 4000xx which won't be matched with your dialpeer 30 in
place.
