06-25-2012 06:21 AM - edited 03-16-2019 11:50 AM
Hello guys!
I have a Build of Materials to order an additional server (Subscriber) for clustering a Cisco Unity Connection 8.5 (Publisher) already in production. The BoM is as follows:
For Server Platform (Subscriber):
<TABLE style="WIDTH: 548pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=730 mcestyle="width: 548pt; border-collapse: collapse;">
<TR style="HEIGHT: 15pt" mcestyle="height: 15pt;">
<TD style="WIDTH: 239pt; HEIGHT: 15pt" height=20 width=318 mcestyle="width: 239pt; height: 15pt;">MCS7825I5-K9-UCC2</TD>
<TD style="WIDTH: 309pt" width=412 mcestyle="width: 309pt;">CUCxn 8.5 MCS-7825-I5, 2x250 HDD, 4GB RAM IBM</TD></TR>
<TD style="HEIGHT: 15pt" height=20 mcestyle="height: 15pt;">UNITY-PWR-US
Power Cord - US, Can, Mex, PR, Phil, Ven, Tai, Col, Ecu |
<TD style="HEIGHT: 15pt" height=20 mcestyle="height: 15pt;">CON-SNT-7825I5K9
SMARTNET 8X5XNBD CUCxn 8.5 MCS-7825-I5, 2x250 HDD, 3GB RA |
For license Upgrade:
<TD style="WIDTH: 219pt; HEIGHT: 15pt" height=20 width=292 mcestyle="width: 219pt; height: 15pt;">L-UNITYCN8-LIC-UPG</TD>
<TD style="WIDTH: 272pt" width=362 mcestyle="width: 272pt;">Unity Connection 8.x, SW Feature License Add-ons</TD></TR>
<TD style="HEIGHT: 15pt" height=20 mcestyle="height: 15pt;">L-UNCN8-ADD-PORT
Unity Connection 8.x Add Ports |
<TD style="HEIGHT: 15pt" height=20 mcestyle="height: 15pt;">L-UNITYCN8-HA-7825
Unity Connection 8.x HA for 7825 - eDelivery |
<TD style="HEIGHT: 15pt" height=20 mcestyle="height: 15pt;">Included: L-UNITYCN8-HA-PAK
Unity Connection 8.x HA PAK |
<TD style="HEIGHT: 15pt" height=20 mcestyle="height: 15pt;">Included: L-UNITYCN8-PAK
Unity Connection 8.x PAK |
<TD style="HEIGHT: 15pt" height=20 mcestyle="height: 15pt;">CON-ESW-LUNITYCN
ESSENTIAL SW Unity Connection 8.x, SW Feature License |
The exisitng Publisher has 96 ports. My question is the following:
Does the Subscriber needs to have the same amount of voice ports as the Publisher? It is neccessary to order the L-UNCN8-ADD-PORT with the same quantity as the Publisher?
Thanks in advanced guys!
<BR type="_moz" mozdirty></P>
Solved! Go to Solution.
06-25-2012 06:29 AM
The servers in a Unity Connection cluster would ideally have the same number of ports. I believe the port SKU is (or used to be) specific to HA (e.g.,
L-UNCN8-ADD-HA-PT). You should be able to verify the part number for the HA when you make an order.
Hailey
Please rate helpful posts!
06-25-2012 06:28 AM
My bad for the garbage guys. When I pasted the BoM it got screwed.
MCS7825I5-K9-UCC2 CUCxn 8.5 MCS-7825-I5, 2x250 HDD, 4GB RAM IBM
UNITY-PWR-US Power Cord - US, Can, Mex, PR, Phil, Ven, Tai, Col, Ecu
CON-SNT-7825I5K9 SMARTNET 8X5XNBD CUCxn 8.5 MCS-7825-I5, 2x250 HDD, 3GB RA
L-UNITYCN8-LIC-UPG Unity Connection 8.x, SW Feature License Add-ons
L-UNCN8-ADD-PORT Unity Connection 8.x Add Ports
L-UNITYCN8-HA-7825 Unity Connection 8.x HA for 7825 - eDelivery
Included: L-UNITYCN8-HA-PAK Unity Connection 8.x HA PAK
Included: L-UNITYCN8-PAK Unity Connection 8.x PAK
CON-ESW-LUNITYCN ESSENTIAL SW Unity Connection 8.x, SW Feature License
06-25-2012 06:29 AM
Hailey
06-25-2012 06:46 AM
Excellent, thanks a lot David!
