Cisco VCS Expressway on BE6K
Bo Bo Aung
Dear All,
I have some question regarding cisco expressway on BE6K.
we ordered BE6K loaded VCS Expressway on it.
After system has been power up and at the end of the boot process system brought me to Cisco login console instead Vmware Configuration page
I thought that software ova is loaded on Esxi host. now is directly loaded on physical machine.
Anyone able to confirm me regarding above mentioned?
Thanks in advance!
Chris Deren
So, the server does not have ESXi installed? I don't think you can install Expressway directly on the server without vmware, so something does not make sense.  Can you provide screen shot of the screen you are seeing?
George Thomas
Level 10
Level 10
Did you buy Be6K or CE500/CE1000?
Please rate useful posts.
Dear Thomas,
How can I check my server is BE6K or CE500/CE1000?
On the servers faceplate it should say M3SBE or something like that.
