Cisco voice gateway reporting.
r.boloor.rao
We have Cisco gateway with PRI connection. Is there any way /tool we can use monitor and extract reoprt?.
1. We want to know how many calls GW handled between two date/time.
2. What was the max concurrent calls (both incoming and outgoing) : kind of trunk utilization for any date.
TIA
boris.kudr
What you need is a some kind of billing solution which accepts RADIUS accounting messages from the gateway and stores it in a database for later analysis.
Open source example:
http://wiki.freeradius.org/SQL-HOWTO
Or, you can use Cacti/MRTG to build graphs according to utilisation data retrieved via SNMP:
https://supportforums.cisco.com/thread/280236
D_Lebedev
Level 3
Level 3
Cisco Real-Time Monitoring Tool
You can install it from UCMAdmin---Application--plugins...
