01-30-2017 12:34 AM - edited 03-17-2019 09:20 AM
Hi;
We recently replaced a 2811 router running CUCME 7.1 with a Cisco 4431 running CUCME 10.5, we have migrated the configuration from the old router to the new router. The IP phones on my LAN network registered and works perfectly with the new router.However the IP phones on my LAN can't make phones calls to the Branches where we have cisco 2811 running CUCME 7.1, i have configured the dial-peers pointing the branch router but still can't make calls there, the IP Phone gives an error message " Unkwon Number".
The tricky part is that from the branches they can call on my LAN without any problem.
Has anyone faced this before? Am still new to IP telephony.
01-30-2017 02:09 AM
Have you configured correct outgoing dial peer
Anoop
01-30-2017 03:07 AM
Hello;
here is the dial peer configured.
dial-peer voice 51 voip
destination-pattern 13..
session target ipv4:192.168.1.105
01-30-2017 08:36 PM
Try collecting debug voip ccapi inout from your VG and the Branch VG while you do some failed calls and post it here.
Mike
01-30-2017 09:17 PM
Just try below command in new CME router and check.
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
Starting with 15.1(2)T, the router’s default behavior is to not trust a call setup from a VoIP source. This feature adds an internal application named TOLLFRAUD_APP to the default call control stack, which checks the source IP of the call setup before routing the call. If the source IP does not match an explicit entry in the configuration as a trusted VoIP source, the call is rejected.
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/112083-tollfraud-ios.html
Suresh
01-30-2017 11:22 PM
Hi Suresh;
The above command was added, but still calls to branches didn't go through, though branches can call me.
01-31-2017 03:23 AM
Hi Armand,
Please attach "debug voip ccapi inout" from both along with "show run" of both CMEs if possible.
Suresh
11-16-2018 12:45 AM
I have this problem too, please what did you do to resolve the issue
p.s
the phone rejects the extension it just dials the first 3 digits and displays unknown number
11-16-2018 12:46 AM
I have this problem too, please what did you do to resolve the issue.
p.s
the phone rejects the extension it just dials the first 3 digits and displays unknown number.
11-19-2018 03:19 PM
We hav the same problem and we observed only on router ISR
Please your support i have 2 router isr 4331 and we have 2 phone 7811 connected on.router A and sccp phone 6921 connect on.router B. The destination-patern on router B is 5130. When 7811 try to call 6921 we hav not a problem. So when 6921 try to call only 4 digit was forwad and the router cannot now (.) Or other symbol. We observed this problem only on router isr. Can you help please
11-20-2018 12:49 AM
11-20-2018 02:34 AM
Bonjour,
please find below
Nov 20 10:21:56.949: //-1/F16045FF8086/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=51100
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFFFFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Nov 20 10:21:56.950: //-1/F16045FF8086/CCAPI/cc_api_call_setup_ind_common:
Interface=0x7F35F053B318, Call Info(
Calling Number=51100,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=20016, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Nov 20 10:21:56.950: //-1/F16045FF8086/CCAPI/ccCheckClipClir:
In: Calling Number=51100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=51100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Nov 20 10:21:56.950: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 20 10:21:56.950: :cc_get_feature_vsa malloc success
Nov 20 10:21:56.950: cc_get_feature_vsa count is 1
Nov 20 10:21:56.950: :FEATURE_VSA attributes are: feature_name:0,feature_time:139869573970028,feature_id:43
Nov 20 10:21:56.950: //43/F16045FF8086/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=51100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
Nov 20 10:21:56.950: //43/F16045FF8086/CCAPI/cc_process_call_setup_ind:
Event=0x7F35EC47AB60
Nov 20 10:21:56.951: //43/F16045FF8086/CCAPI/ccCallSetContext:
Context=0x7F35F11AC730
Nov 20 10:21:56.951: //43/F16045FF8086/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 43 with tag 20016 to app "_ManagedAppProcess_Default"
Nov 20 10:21:56.951: //43/F16045FF8086/CCAPI/ccCallSetupAck:
Call Id=43
Nov 20 10:21:56.951: //43/F16045FF8086/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
Nov 20 10:21:56.951: //43/F16045FF8086/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=43
Nov 20 10:21:56.951: //43/F16045FF8086/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
Nov 20 10:21:56.952: //43/F16045FF8086/CCAPI/ccSetDigitTimeouts:
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Nov 20 10:21:56.952: //43/F16045FF8086/CCAPI/ccCallReportDigits:
(callID=0x2B, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Call Id=43
Nov 20 10:21:56.952: //43/F16045FF8086/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x7F35F053B318, callID=0x2B, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Disposition=0x0, Interface=0x7F35F053B318, Call Id=43
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=5000(ms))
Nov 20 10:21:57.832: //43/F16045FF8086/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Source Call Id=43, Digit=5, DigitBeginFlags=0x0,
Rtp Timestamp=0x2F68B8, Rtp Expiration=0x0
Nov 20 10:21:57.832: //43/F16045FF8086/CCAPI/cc_api_call_digit_end:
Source Call Id=43, Digit=5, Duration=100,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Call Entry(Handoff Depth=0)
Nov 20 10:21:58.034: //43/F16045FF8086/CCAPI/cc_api_call_digit_begin:
Source Call Id=43, Digit=1, DigitBeginFlags=0x0,
Rtp Timestamp=0x2FE5B8, Rtp Expiration=0x0
Nov 20 10:21:58.034: //43/F16045FF8086/CCAPI/cc_api_call_digit_end:
Source Call Id=43, Digit=1, Duration=100,
Nov 20 10:21:58.232: //43/F16045FF8086/CCAPI/cc_api_call_digit_begin:
Source Call Id=43, Digit=3, DigitBeginFlags=0x0,
Rtp Timestamp=0x3062B8, Rtp Expiration=0x0
Nov 20 10:21:58.232: //43/F16045FF8086/CCAPI/cc_api_call_digit_end:
Source Call Id=43, Digit=3, Duration=100,
Nov 20 10:21:58.432: //43/F16045FF8086/CCAPI/cc_api_call_digit_begin:
Source Call Id=43, Digit=0, DigitBeginFlags=0x0,
Rtp Timestamp=0x30DFB8, Rtp Expiration=0x0
Nov 20 10:21:58.432: //43/F16045FF8086/CCAPI/cc_api_call_digit_end:
Source Call Id=43, Digit=0, Duration=100,
Nov 20 10:21:58.432: //43/F16045FF8086/CCAPI/ccCallReportDigits:
(callID=0x2B, digit_event=0x0, enable=FALSE, consume=FALSE)
Nov 20 10:21:58.432: //43/F16045FF8086/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x7F35F053B318, callID=0x2B, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Nov 20 10:21:58.432: //43/F16045FF8086/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
Nov 20 10:21:58.434: //43/F16045FF8086/CCAPI/ccCallDisconnect:
Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Nov 20 10:21:58.434: //43/F16045FF8086/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
Nov 20 10:22:04.338: //43/F16045FF8086/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F35F053B318, Tag=0x0, Call Id=43,
Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Nov 20 10:22:04.338: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 20 10:22:04.338: :cc_free_feature_vsa freeing 7F35EC457860
Nov 20 10:22:04.338: vsacount in free is 0
11-20-2018 02:48 AM
Nov 20 10:47:35.018: //-1/8622D576808A/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=51100
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
Nov 20 10:47:35.018: //-1/8622D576808A/CCAPI/cc_api_call_setup_ind_common:
Nov 20 10:47:35.018: //-1/8622D576808A/CCAPI/ccCheckClipClir:
Nov 20 10:47:35.018: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 20 10:47:35.018: :cc_get_feature_vsa malloc success
Nov 20 10:47:35.018: cc_get_feature_vsa count is 1
Nov 20 10:47:35.018: :FEATURE_VSA attributes are: feature_name:0,feature_time:139869573970028,feature_id:44
Nov 20 10:47:35.018: //44/8622D576808A/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Nov 20 10:47:35.018: //44/8622D576808A/CCAPI/cc_process_call_setup_ind:
Nov 20 10:47:35.019: //44/8622D576808A/CCAPI/ccCallSetContext:
Context=0x7F35F11ADDD8
Nov 20 10:47:35.019: //44/8622D576808A/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 44 with tag 20016 to app "_ManagedAppProcess_Default"
Nov 20 10:47:35.019: //44/8622D576808A/CCAPI/ccCallSetupAck:
Call Id=44
Nov 20 10:47:35.020: //44/8622D576808A/CCAPI/cc_api_set_transfer_info:
Nov 20 10:47:35.020: //44/8622D576808A/CCAPI/ccGenerateToneInfo:
Tone Direction=Network, Params=0x0, Call Id=44
Nov 20 10:47:35.020: //44/8622D576808A/CCAPI/ccSetDigitTimeouts:
Nov 20 10:47:35.020: //44/8622D576808A/CCAPI/ccCallReportDigits:
(callID=0x2C, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Call Id=44
Nov 20 10:47:35.020: //44/8622D576808A/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x7F35F053B318, callID=0x2C, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Disposition=0x0, Interface=0x7F35F053B318, Call Id=44
Nov 20 10:47:35.908: //44/8622D576808A/CCAPI/cc_api_call_digit_begin:
Source Call Id=44, Digit=5, DigitBeginFlags=0x0,
Rtp Timestamp=0x31E188, Rtp Expiration=0x0
Nov 20 10:47:35.908: //44/8622D576808A/CCAPI/cc_api_call_digit_end:
Source Call Id=44, Digit=5, Duration=100,
Nov 20 10:47:36.109: //44/8622D576808A/CCAPI/cc_api_call_digit_begin:
Source Call Id=44, Digit=1, DigitBeginFlags=0x0,
Rtp Timestamp=0x325E88, Rtp Expiration=0x0
Nov 20 10:47:36.109: //44/8622D576808A/CCAPI/cc_api_call_digit_end:
Source Call Id=44, Digit=1, Duration=100,
Nov 20 10:47:36.308: //44/8622D576808A/CCAPI/cc_api_call_digit_begin:
Source Call Id=44, Digit=3, DigitBeginFlags=0x0,
Rtp Timestamp=0x32DB88, Rtp Expiration=0x0
Nov 20 10:47:36.308: //44/8622D576808A/CCAPI/cc_api_call_digit_end:
Source Call Id=44, Digit=3, Duration=100,
Nov 20 10:47:36.509: //44/8622D576808A/CCAPI/cc_api_call_digit_begin:
Source Call Id=44, Digit=0, DigitBeginFlags=0x0,
Rtp Timestamp=0x335888, Rtp Expiration=0x0
Nov 20 10:47:36.509: //44/8622D576808A/CCAPI/cc_api_call_digit_end:
Source Call Id=44, Digit=0, Duration=100,
Nov 20 10:47:36.509: //44/8622D576808A/CCAPI/ccCallReportDigits:
(callID=0x2C, digit_event=0x0, enable=FALSE, consume=FALSE)
Nov 20 10:47:36.509: //44/8622D576808A/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x7F35F053B318, callID=0x2C, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Nov 20 10:47:36.509: //44/8622D576808A/CCAPI/ccCallProceeding:
Nov 20 10:47:36.511: //44/8622D576808A/CCAPI/ccCallDisconnect:
Nov 20 10:47:36.511: //44/8622D576808A/CCAPI/cc_api_get_transfer_info:
Nov 20 10:48:06.522: //44/8622D576808A/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F35F053B318, Tag=0x0, Call Id=44,
Nov 20 10:48:06.523: //44/8622D576808A/CCAPI/cc_api_call_disconnect_done:
Nov 20 10:48:06.523: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 20 10:48:06.523: :cc_free_feature_vsa freeing 7F35EC457860
Nov 20 10:48:06.523: vsacount in free is 0
