Clarification on CUCM 9.0 pauses in dialing
djbuechner_2
I have a customer who wants to be able to forward a set of extensions to the various owners' cell phone.  The trick is that most of the cell phones are long distance and outbound long distance calls require an "expense code".  The prompt for the expense code is handled by the LD provider so we need to be able to put pauses in the outbound dialing.  Outbound long distance calls go out over a voice T1 (E&M wink start).
I've been reading the new features in CUCM 9.0 and have noticed that pauses are now supported in Speed Dials.  Are they also supported in other places such as forward strings?
Thanks!
David
Thanks David for testing, +5 for confirming.
HTH, please rate all useful posts!
Chris
Chris Deren
My understating is that this is only for speed dials, though might be worth testing.
HTH,
Chris
Chris,
You are correct - I finally put up a test CUCM to find out and I see no way to add pauses anywhere but speed dials.
Thanks!
David
Chris
paolo bevilacqua
You can use my script "speed-dial with pauses" that can be acquired on the website mentioned in my profile.
Despite the name, it works with any number dialed by the CM.
