Clarify which link of call manger 15 I need
teamdv6199
I am having trouble finding which iso to download for call manger 15. When I started installing the one I found it says its a emergency responder version. Software Download - Cisco Systems
Can someone clarify which one I need?
Vaijanath Sonvane
Hi @teamdv6199,
The link you provided has ISO file which is applicable for upgrades only. If you are looking for bootable ISO file then you need to place an order through MCE portal or open TAC case to publish the file.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Jaime Valencia
Install media is not available for download, you need to get it via MCE, those images are only for upgrades
java
if this helps, please rate
Sorry I need the ISO file. Where is that at?
Vaijanath Sonvane
Hi @teamdv6199,
