CLI Command CUCM to see switchport
asharsidd
Is there any command for CUCM to run from CLI which can give us which switchport it is connected to?
Something like show cdp neighbor.
I have tried different commands from CUCM CLI but none of them is giving this basic information.
Is there a SQL query or somethin which can provide such detail?
Any help would be much appreciated.
I tested this in the lab and it looks like the CDP traces aren't detailed enough to print the actual port information.  Your other option is to just take a network capture from CUCM and download it with RTPT then filter for CDP traffic.
utils network capture eth0 file cdp.cap size all count 100000
15 Replies 15
brmeade
Level 4
Level 4
You can watch the CDP trace in real-time and just wait up to 60 seconds for the next broadcast.
file tail activelog cm/trace/cdp/sdi/ recent
Hi Brain,
It is intresting that we can get this info.
Do u have any such snapshot with u ?
regds,
aman
Hi Brian, thanks for that command.
I tried it but I am still not getting switchport information.
Can you please help if I am missing something here.
admin:file tail activelog cm/trace/cdp/sdi/ recent
|<:MY_CLUSTERID><:MY_NODEID><:ERROR><:0001>
04/25/2013 14:58:47.512 CDP Daemon|-->cdp_read_tlv_duplex() |<:MY_CLUSTERID><:MY_NODEID><:ENTRY_EXIT><:0001>
04/25/2013 14:58:47.512 CDP Daemon|   cdp_read_tlv_duplex() Inside cdp_read_tlv_duplex method
04/25/2013 14:58:47.512 CDP Daemon|   cdp_read_tlv_duplex()  Method cdp_read_tlv_duplex ends
04/25/2013 14:58:47.512 CDP Daemon|<--cdp_read_tlv_duplex() |<:MY_CLUSTERID><:MY_NODEID><:ENTRY_EXIT><:0001>
04/25/2013 14:58:47.512 CDP Daemon|   cdpd_read_Cache() Duplex Match, full
|<:MY_CLUSTERID><:MY_NODEID><:SIGNIFICANT><:0001>
04/25/2013 14:58:47.512 CDP Daemon|<--cdpd_read_Cache() |<:MY_CLUSTERID><:MY_NODEID><:ENTRY_EXIT><:0001>
Control-C pressed
admin:
admin:
CCM:
admin:show version active
Active Master Version: 7.1.3.32900-4
You would be getting file name like  ccm00000001.txt. Check for the recent one like ccm00000004.txt
regds,
aman
Hi Aman, where is the filename in my output I posted before..I cannot see any!
I t should be file tail activelog cm/trace/cdp/sdi/?
Press enter .U should be able to find the file.
Can u share the output of this command.?
regds,
aman
admin:file tail activelog cm/trace/cdp/sdi/?
Syntax:
file tail activelog file-spec [options]
file-spec   mandatory   file to tail
options     optional    hex,[num lines],regexp "expression"
                        recent : to tail the most recently changed file in the directory.
admin:file tail activelog cm/trace/cdp/sdi/.
Executed command unsuccessfully
tail: error reading `/var/log/active/cm/trace/cdp/sdi/.': Is a directory
tail: /var/log/active/cm/trace/cdp/sdi/.: cannot follow end of this type of file; giving up on this name
tail: no files remaining
admin:file tail activelog cm/trace/cdp/sdi/ .
tail: error reading `/var/log/active/cm/trace/cdp/sdi/': Is a directory
tail: /var/log/active/cm/trace/cdp/sdi/: cannot follow end of this type of file; giving up on this name
admin:
OK, first of all we need to run file list command to see which one is latest.
# file list activelog cm/trace/cdp/sdi/
I got a long list, the file at the end should be recent one cdpd000000250.txt
then I ran file view command
# file view activelog cm/trace/cdp/sdi/cdpd000000250.txt
I still cannot see switchpoport!
04/25/2013 07:51:20.486 CDP Daemon|   cdpd_xml_process_doc() what do we have here in doc: GetInterface
04/25/2013 07:51:20.486 CDP Daemon|-->cdpd_get_ifname() |<:MY_CLUSTERID><:MY_NODEID><:ENTRY_EXIT><:0001>
04/25/2013 07:51:20.486 CDP Daemon|<--cdpd_get_ifname() |<:MY_CLUSTERID><:MY_NODEID><:ENTRY_EXIT><:0001>
04/25/2013 07:51:20.486 CDP Daemon|-->is_accessible_interface() |<:MY_CLUSTERID><:MY_NODEID><:ENTRY_EXIT><:0001>
04/25/2013 07:51:20.486 CDP Daemon|<--is_accessible_interface() |<:MY_CLUSTERID><:MY_NODEID><:ENTRY_EXIT><:0001>
04/25/2013 07:51:20.486 CDP Daemon|-->cdpd_get_ip_addr() |<:MY_CLUSTERID><:MY_NODEID><:ENTRY_EXIT><:0001>
04/25/2013 07:51:20.486 CDP Daemon|<--cdpd_get_ip_addr() |<:MY_CLUSTERID><:MY_NODEID><:ENTRY_EXIT><:0001>
04/25/2013 07:51:20.504 CDP Daemon|-->cdp_get_if_flags() |<:MY_CLUSTERID><:MY_NODEID><:ENTRY_EXIT><:0001>
04/25/2013 07:51:20.504 CDP Daemon|<--cdp_get_if_flags() |<:MY_CLUSTERID><:MY_NODEID><:ENTRY_EXIT><:0001>
04/25/2013 07:51:20.504 CDP Daemon|-->cdpd_get_ifname() |<:MY_CLUSTERID><:MY_NODEID><:ENTRY_EXIT><:0001>
04/25/2013 07:51:20.504 CDP Daemon|<--cdpd_get_ifname() |<:MY_CLUSTERID><:MY_NODEID><:ENTRY_EXIT><:0001>
04/25/2013 07:51:20.504 CDP Daemon|-->is_accessible_interface() |<:MY_CLUSTERID><:MY_NODEID><:ENTRY_EXIT><:0001>
04/25/2013 07:51:20.504 CDP Daemon|<--is_accessible_interface() |<:MY_CLUSTERID><:MY_NODEID><:ENTRY_EXIT><:0001>
options: q=quit, n=next, p=prev, b=begin, e=end (lines 1901 - 1920 of 9338) :
04/25/2013 07:51:20.504 CDP Daemon|   cdpd_xml_process_doc() Response sending to client is Number of Interfaces=3
Interface Name=eth0
Interface IP=10.159.x.x
Status=1
IsInterfaceDisable=0
Interface Name=eth1
Interface IP=n/a
Status=0
Interface Name=sit0
Interface IP=n/a
Status=0
, length 234
04/25/2013 07:51:20.504 CDP Daemon|-->ayrxml_send_printbuf() |<:MY_CLUSTERID><:MY_NODEID><:ENTRY_EXIT><:0001>
You can download this file sftp.
May be some of the lines have got skipped.
regds,
aman
Attached is the file.
I can see the switch type but still can't see which port CCM is connected.
Please see and let me know if I have missed it.
Thanks Brian.
This is what I wanted to confirm as one of our customer asked this question and at first I thought there will be some command which will provide us this information but to my surprise found none. I think Cisco should introduce this in next releases as it can be very helpful.
Hi Brian,
Thanks for reply.
I was just seeing the logs captured by Asharsidd and see only 6509 switch.
regds,
aman
Brian, You are absolutely spot on..I ran a capture from CUCM CLI (f0r about 1 minute) and filtered on "cdp" and bingo I see the switch and port this server is connected to...Really good to know..Thanks
600 13.508540 Cisco_73:5f:b1 CDP/VTP/DTP/PAgP/UDLD CDP 482 Device ID: BN1UK-OX-CSW01.X1.com  Port ID: FastEthernet1/34
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
