Closed greeting every time
Shan28
have to play closed greeting every time in CUC.
Number is no more in use, so customer want to hear closed greeting every time for particular extension.
Just let the call go to CUC and there you create a call handler that have the extension you want to play the message for. On the CH set standard greeting to play and upload the message to it. Easiest way to get the call to CUC is to set the DN you no longer have on any phones up on a CTI RP and set CFA to voicemail.
Response Signature
5 Replies 5
what you mean by transferring call ?
number not used means, extension not configured on any phones and you need to have message played when calling this number ??
Response Signature
Hello Nithin,
Thanks for reply,
We have extension configured as shared line..dont want to use this extension any more..
So if customer dial that extension in future, he should hear a prompt "this brand is closed" kind of..
Response Signature
Hi Roger,
yeah..it is working..
thank vry much..
Glad to hear that and your welcome.
Response Signature
