06-08-2013 07:56 AM - edited 03-16-2019 05:46 PM
We have a cm express and the 7905g doesnt register. We have a dhcp pool de fined in cme and the phone take the IP from the dhcp, we have t'he fw load belong
To 7905 but when we do
sh ephones
The 7905 are not registered
Anna
Solved! Go to Solution.
06-11-2013 09:46 AM
There are many threads about, you can use the search function.
06-08-2013 08:38 AM
Anna,
Please post a full configuration of your cme router.
Yosh
06-08-2013 08:57 PM
Morning,
I would be checking a few things.
1. Under Telephony service do you have the type defined
2. Is the firmware for the phone on your flash and defined in configuration
3. Debug TFTP and check that the phone is requesting and receiving the firmware defined in Telephony Service
Lastly make sure you issue the create cnf-files command,
Let me know how you go.
06-10-2013 02:14 AM
Sorry for delay and thanks.
Anna
Here the sh run:
Router#sh run
Building configuration...
Current configuration : 1177 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
enable password ceci
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp pool VOICE
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
option 150 ip 192.168.1.1
dns-server 192.168.1.1
no ip domain lookup
ip dhcp-server 192.168.1.1
interface FastEthernet0/0
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
telephony-service
load 7905 CP7905060101SCCP050429A
max-ephones 5
max-dn 10
ip source-address 192.168.1.1 port 2000
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 4 gain -6
ephone-dn 1
number 3001
ephone-dn 2
number 3002
ephone 3
mac-address 000C.CE34.3AA8
type 7905
button 1:1
ephone 4
mac-address 0003.FFD4.23C5
type CIPC
button 1:2
ephone 5
line con 0
password ceci
login
line aux 0
line vty 0 4
password ceci
login
end
06-10-2013 02:19 AM
Bendatcrox,
I answer you:
Router#
*Jun 10 11:12:09.785: TFTP: Looking for ld000cce343aa8
*Jun 10 11:12:09.797: TFTP: Looking for lddefault.cfg
Router(config-telephony)#create CNF-files
CNF file creation is already On
Updating CNF files
%Error deleting flash:SEPDEFAULT.cnf (No such file or directory)
%Error deleting flash:XMLDefault.cnf.xml (No such file or directory)CNF-FILES: C
lock is not set or synchronized,
retaining old versionStamps
CNF files update complete
Thanks Anna
06-10-2013 08:43 AM
Hey Anna,
Can you please send me the output of -
show telephony-service tftp-bindings
Thanks.
06-10-2013 08:47 AM
Router#show telephony-service tftp-bindings
tftp-server system:/its/SEPDEFAULT.cnf
tftp-server system:/its/SEPDEFAULT.cnf alias SEPDefault.cnf
tftp-server system:/its/XMLDefault.cnf.xml alias XMLDefault.cnf.xml
tftp-server system:/its/ATADefault.cnf.xml
tftp-server system:/its/XMLDefault7905.cnf.xml alias SEP000CCE343AA8.cnf.xml
tftp-server system:/its/XMLDefaultCIPC.cnf.xml alias SEP0003FFD423C5.cnf.xml
tftp-server system:/its/united_states/7960-tones.xml alias United_States/7960-to
nes.xml
tftp-server system:/its/united_states/7960-font.xml alias English_United_States/
7960-font.xml
tftp-server system:/its/united_states/7960-dictionary.xml alias English_United_S
tftp-server system:/its/united_states/7960-kate.xml alias English_United_States/
7960-kate.xml
tftp-server system:/its/united_states/SCCP-dictionary.xml alias English_United_S
tates/SCCP-dictionary.xml Router#show telephony-service tftp-bindings
nes.xml
7960-font.xml
7960-kate.xml
06-10-2013 09:02 AM
Can you please go into the phone menu and go to the status screen and tell me what version of the firmware the phone is currently running.
Thanks.
06-10-2013 10:19 AM
Hi bendatcrox
I am out of office now, but version IP phone could be 8... Could be it the problem??
Anna
06-11-2013 03:29 AM
Hi Bendatcrox,
finally the ip phone version is 8.0.1
thanks
Anna
06-11-2013 07:09 AM
Did these ever before worked? Could have SIP firmware.
06-11-2013 05:37 AM
Anna,
You need to paste the "tftp-server flash:" commands from the "cme-readme" file stored on your flash. Also you will probably need paste the following command afterwards "tftp-server flash:/phone/7905/
http://voiceonbits.com/2010/07/06/cme-basic-setup/
Yosh
06-11-2013 08:27 AM
Hi Paolo,
you are right!! this ip phone were worked before and his fw is SIP. Anybody knows the procedure to change it to sccp???
thanks
Anna
06-11-2013 09:46 AM
06-12-2013 09:02 AM
Hi everybody,
The proble was that the phone has SIP fw,
thanks everybody
Anna
