03-03-2011 02:13 PM - edited 03-16-2019 03:46 AM
Hi All,
I have an UC520 with CME7.1 and i configured extension mobility with ipphone as exemple bellow:
voice logout-profil 14
pin 1111
user aaaa password aaaa
number 4444 type normal
ephone 14
mac-address A8B1D4FA8805
type 7942
logout-profile 14
voice user-profile 14
pin 123456
user xxxx password xxxx
number 4444 type feature-ring
speed-dial 1 4445 label test
ephone-dn 14 dula line
number 4444
label test
description 4444
name test
and it's work fine.
but what i dont know to do is how to restrict call when i'm logged out .
i want that ipphone logged out can't make outgoing call just internal call.
and when i logged in with profile then i can make any call.
thanks for help
03-04-2011 02:04 AM
any help plz,
03-07-2011 04:18 AM
Hi all,
any body can help here, is it clear what i want??
thanks
10-15-2012 03:19 PM
Hi yoyo,
Could you set call restriction using Extension Mobility ??
regards
10-15-2012 03:34 PM
Please take a moment to review the cme configuration guide regarding call blocking through COR. See the following I believe this is what you are looking for.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeblock.html#wp1014495
Allan
10-15-2012 03:41 PM
Hi allan,
thanks for your reference, as a matter of fact I know how to apply cor list for restriction in dial-peer and ephone- dn, the issue is how to apply in extension mobility phone directory, I can`t find any option to associate cor list.
regards
