12-07-2011 10:02 AM - edited 03-16-2019 08:25 AM
I have followed advice on previous posts by performing the following initial actions to fix the 7941 Phone displaying the wrong time. Interesting thing is that other 7941 phones are displaying correct time.
ephone 12
device-security-mode none
mac-address XXXX.XXXX.XXXX
username "XXXXXXX" password XXXX
paging-dn XXX
type 7941
button 1:12
SCCP41.8-5-4S
One peculiar thing I noticed is that while other phones have the time zone specified (PDT) this problem phone does not.
Any advice as to what else to try would be greatly appreciated.
Adil
Solved! Go to Solution.
12-07-2011 10:15 AM
Hi Adil,
Can you please try;
under the telephony-service -
no create cnf-files
create cnf-files
Then reboot the individual phone
Cheers!
Rob
12-07-2011 10:15 AM
Hi Adil,
Can you please try;
no create cnf-files
create cnf-files
Cheers!
Rob
12-07-2011 10:30 AM
yep that fixed the issue. Thanks.
